Results 31 to 40 of 60
- Jun 2005
- 3,774
- Mar 2014
- 901
September 20th, 2015 11:38 PM #32If all models of Altis develops an oil sludge like you were saying. The design in its oil distribution and recirculation inside the engine might be poor or not properly designed.
An ordinary/special mineral engine oil, 10w-40, always works best to all types of passenger cars/vehicles. Definitely with following the regular interval of changing engine oil.
And synthetic engine oils is only used and designed to work for high speed turbine engine, which have extreme heat during operations that no ordinary/special engine oil can dissipate it.
Sent from my UP+ using Tapatalk
- Jun 2005
- 3,774
September 21st, 2015 07:47 AM #33
- Jul 2015
- 59
September 24th, 2015 01:38 AM #34medyo madugo ang nagastos ko sir, pero ayos magtrabaho yun shop na napuntahan ko. And half day lang natapos nila. 4 mechanics nagtulong tulong sabi kasi nila kung walang tama sa loob ng engine cleaning nila at palitan ibang parts kaya matapos ng half day.
Labor = 18,000 (medyo mahal ito tingin ko, unang una 20k dapat, tinawaran ko kasi sabi ko half day lang naman and walang tama yun makina)
valve cover surplus = 2000 (wala daw mabiling original or new replacement nito kaya surplus ang kinuha ko)
4 listers of flushing oil = 500
4 bottles of motor oil ordinary = 800 (for change oil)
1 oil filter = 180
10 cleaner (200 each bottle) = 2000 (ito yun ginamit na panglinis sa loob ng makina, parang spray sya)
valve gasket rubber (yun rubber na black dunno if tama yun name) replacement = 650 (malutong na daw kasi kaya nagleleak yun oil dati)
kerosene = 200 (pang linis ng makina)
Inabot ako kulang kulang na 25000, medyo mahal sya pero maayos at mabilis yun trabaho and surplus shop din kasi sya kaya kung may mga parts na walang mabili, sa surplus na kumukuha.
Right now, mas maganda na yun tunog ng makina.
- Jun 2005
- 3,774
September 24th, 2015 03:23 AM #36masyado pala mahal inabot mo. harang ang labo.mas mahal pa than having a decent overhaul.
valve cover? yung buong valve cover pinalitan or gasket lang? kung gasket lang, loko nga yung shop. dami VC gaskets sa banawe. less than 500 lang replacements and gaskets should never be surplus.
September 24th, 2015 04:10 AM #37
imo mahal ang labor na 18k sir...parang taga sa presyo yan. Nagpa TOH ako dati and if I remember it right wala pa sa 6k labor na binayaran ko. Yung friend ko na naputulan ng timing belt, 15k lang nagastos nya all in...palit valve pa yun.
With regards sa valve cover, yung buong cover pinalitan? if gasket lang kase like sir sirkosero said...impossible walang oem or replacement nyan...and dapat bnew gamitin kung papalitan.
- Jul 2015
- 59
October 14th, 2015 09:20 AM #38
- Jul 2015
- 59
October 14th, 2015 09:20 AM #39
- Jul 2015
- 59
October 14th, 2015 09:22 AM #40
