Results 1 to 8 of 8
- Apr 2009
- 272
August 22nd, 2017 07:08 PM #1I was using Havoline 20w50 before and have not encountered any leak. But recently after changing it to 10w40 from shell high mileage oil, Ive seen several leaks below the thermostat area and some around the gasket cover. My valve gasket cover was actually newly replaced before the change oil. Is this a major engine problem? Ride was actually smoother after changing it to 10w40. Problem is yung oil leak. Car is corolla 1997 gli 1.6. 120k mileage.
August 22nd, 2017 07:17 PM #2
bala hindi maganda pag tighten ng cover. problem with some mechanics they dont use a proper torque wrench, though some medyo kabisado ang tamang pag sikip.
if there is a leak sa thermostat.. its a gasket issue... baka nabuksan at ni-reuse ang old gasket...
- Oct 2009
- 2,271
August 24th, 2017 08:25 PM #3mas manipis ung nilagay na bagong langis syempre magkakaroon talaga ng leak
August 24th, 2017 08:59 PM #4
any oil thins out after normal use, xw50 becomes xw40 or even lower...
- May 2011
- 481
August 24th, 2017 09:02 PM #5engine oil viscosity vs temperature - Google Search
Wrong guess. There must be a loose fastener, a damaged gasket, damaged gasket mating surface or foreign object interfering the gasket contact. Viscosity has nothing to do with it specially they are not far apart and the temperature range for the latter oil is within the temperature index
- May 2011
- 481
August 24th, 2017 09:04 PM #6engine oil viscosity vs temperature - Google Search
Wrong guess. There must be a loose fastener, a damaged gasket, damaged gasket mating surface or foreign object interfering the gasket contact. Viscosity has nothing to do with it special they are not far apart and the temperature range for the latter oil is within the temperature index
- Jan 2010
- 283
August 24th, 2017 09:23 PM #7Check you PCV valve. Regardless which oil you use if the crankcase pressure is high, oil will find the nearest or weakest exit.
- Jul 2016
- 939
August 24th, 2017 11:46 PM #8
Something about the additive not just the grade...
Oil hardening oil seals? | Passenger Car Motor Oil (PCMO) - Diesel Cars/Vans/SUVs | Bob Is The Oil Guy
Tesla Philippines
