Results 1 to 10 of 11
- Feb 2006
- 771
March 31st, 2009 12:36 AM #1hi po,
just recently changed my timing belt , napansin ko po medyo gumanda yung idling and much smoother po yung tunog ng engine ko.
i noticed lang po that ngayon during starting po is medyo di na one click yun starting ko,as in medyo hirap po sya magstart .ideally po ba the timing of the engine is checked after the replacement of the T belt?
salamat po mga sir
March 31st, 2009 03:35 AM #2
You must set your timing by using timing light to ensure your car BTDC this allows the fuel mixture to have a more comlete burn ensuring full power to the compression stroke. You have to know your engine timing, different car have different timing and no idea what kind of vehicle you drive.
March 31st, 2009 10:34 AM #3
THE AUTO SPECIALIST
- Mar 2006
- 607
- Jan 2008
- 380
March 31st, 2009 06:24 PM #6
sama ko na din dito sa thREAD ok lang ba sa L3 na hindi na paganahin ang timing belt i mean e yung sa langis ba yun o maliit na timing belt?
- Feb 2006
- 771
April 1st, 2009 01:10 AM #7power ?hmmmm medyo smooth lang sir.not sure sa power
and also my ride is Galant 7G po pala .
i also noticed that during idling po pala something like parang nabubulunan or parang sinisinok yung idle nya.
thank you po sa mga inputs.
- Nov 2008
- 148
April 2nd, 2009 12:45 AM #10
Baka lumampas ng ipin yung camshaft pulley nung binalik yung timing belt. Have a mitsu expert correct your camshaft position/valve timing. Kung swak naman yung timing marks eh no need to adjust your ignition timing.
Tesla Philippines
