Results 1 to 10 of 12
- Sep 2010
- 6
November 25th, 2010 07:14 PM #1Mga Experts need help po bumili ako ng sentra kanina lang pag start ko ok naman tapos nag pa gas ako nung iistart ko na ulit walang redondo tas after mga 3min. nag start ulit. ano po possible problem nito need your opinion. tnx
- Sep 2010
- 6
November 25th, 2010 07:17 PM #2sabi ng owner 5 days daw niya hinde na start so possible ba na batt ang problema?
- Nov 2009
- 456
November 26th, 2010 02:03 PM #3Take your car to a battery shop and have them measure the battery's voltage. Have them check the terminal clamps to see if they are clean and tight.
If the battery and alternator status are ok, take the car to your mechanic for a general tune-up (standard procedure when purchasing a 2nd hand vehicle).
Have the spark plugs replaced, check the condition of the high tension wires and ignition coil.
- Sep 2010
- 6
November 26th, 2010 04:09 PM #4dinala ko po kanina sa speedyfix shaw pina check ko sabi nila starter daw madami carbon so pinalinis ko pina change oil ko at spark plug palit din and air filter palit. tas 1 click na start agad tas pag uwi ko tinry ko ulit. ganoon na naman ayaw mag start
- Jun 2010
- 76
November 27th, 2010 10:56 PM #5sir anu po ba ang sintomas hard starting niya pag lumabas..
1.meron bang cranking na nangyayari tapos ayaw magstart.
kung ganito ang ang nangyayari pwede na sensor related ang problima niya.
2.)kung wala nangyayari na cranking..hindi yun hard starting ang problima.
magiging engine won't crank..so ang trouble area niya ay sa starter system..so ang kailangan perform na checking dyan ay ganito.
1) performance test.
2) no load test
3) hold in and pull in test.
para malaman mo kung alin ang sira niya yan ang kailangan gawin..
- Jun 2010
- 76
November 27th, 2010 11:00 PM #6sir anu po ang sintomas ng hard starting mo
meron bang cranking o wala pag lumalabas ang trouble..
kung meron cranking malaman na sensor related yun..
kung wala naman at ok ang battery voltage..need na performed
ang starter checking.
1.)performance test
2.)no load test
3)pull-in and hold-in test
dyan mo malalaman kung anu ang sira ng starter mo..
check mo na lang yun private message mo..
- Sep 2010
- 6
November 28th, 2010 05:25 PM #7ok na po starting na dinala ko sa kapitbahay namin. nung dinala ko sa speedyfix tingal nila yung starter pero hindi nila banilik yung wire galing sa battery.
November 28th, 2010 08:26 PM #8
- Sep 2010
- 6
November 29th, 2010 05:57 PM #9ok na po yung car wala na problem.. pina check ko sa kapitbahay ko ang findings niya hinde nakakabit yung wire from battery to starter so walang ground hirap mag start.
- Sep 2010
- 6
November 29th, 2010 05:58 PM #10pero bakit nung dinala ko sa speedyfix tingal nila yung starter bkt hinde nila kinabit yung wire??
Tesla Philippines
