Results 1 to 6 of 6
- Jun 2010
- 3
June 19th, 2010 03:07 PM #1more power to tsikot
I'm a new car owner, i have a 91' galant gti 16v 4g63 engine
i had the year for about a year now.. and is experiencing a couple of issues lately
i observed that my car is loosing its power,
1.) rpm is dropping badly specially when the ac, lights and stereo is on..
2.) the engine sounds like a diesel engine, and i saw some oil around the spark plug
3.) oil seals under the engine are leaking and the smoke coming out from the exhaust smells bad..
i believe i need a major repairing to do with my car..and badly needs help cause i don't know much about cars yet.
is my engine for a total overhaul and how much would it cost?
and do you know any good mechanics for this kind of car
hoping to hear from you guys.. badly needs help/
thank you!
June 19th, 2010 03:13 PM #2
I am not sure of the cost but your problem sounds like the cylinders have lost compression due to leaks in the head gasket.
Best to have a qualified shop check and give you an estimate on repair cost.
If you dont know any shops, you tell us your area and we can try to suggest one nearby.
- Jun 2010
- 3
June 19th, 2010 06:56 PM #3appreciate your comment..
hmmm... so its the head gasket..
im in san jose del monte bulacan...
do you recommend dukot of the engine for this?
June 19th, 2010 08:00 PM #4
Find someone you trust to endorse a very good mechanic willing to estimate the cost effectiveness of fixing your car. Also someone willing to give options (like replace engine, etc.). A second and even a third opinion might be good.
- Jun 2010
- 3
June 20th, 2010 11:47 AM #6
Given you have mentioned your engine have leaks on the heat and at the oil seals in the engine block, it would be better for a full overhaul to be done.
You have to consider that the engine is nearly 20 years and I assumed it has never been overhauled yet.
As for suggesting a shop... the ones I know are located within Metro Manila. Maybe another tsikot member can suggest a shop nearer to you.
Tesla Philippines
