Results 1 to 10 of 27
    Feb 2013
    Aysus ganun pla.sir bka may idea ka lng kung magkanu aabutin gastos sa paoverhaul?kahit sa parts lang?salamat
    If it's bad, time to start shopping for another engine as well.
    Have your car assessed first before anything else.
    Feb 2013
    sir vinj,wala pa po bsta kinabukasan sinubukan k na paandarin ganun na magkakacrank lng lng o aandar 3 seconds di na totoloy.namamatay.kung ganung mas mabuti b chang engine kaysa overhaul?
    Quote Originally Posted by glxexurb View Post
    It depends on the extent of the damage that's why it's better to have your suking mekaniko assess things first. If there is damage to the engine block, some suggest having the block repaired at a machine shop while i myself would rather look for a surplus block or even fresh engine then recondition it before dropping it in.
    I would agree with Vinj. Damage to the engine is hard to repair. If you've only got worn out gaskets from overheating then all you need is a top overhaul but anything worse than that... Well... Let's just say that replacing the engine would save you more in terms of time and resources.
    Jul 2006
    +1. If it wont start, the internals are already binded.
Nag-overheat,ayaw na umandar
