Results 1 to 1 of 1
August 1st, 2012 01:47 PM #1
A little bit of Repair history:
Replaced front oil seal, first 3 were NOK regular and corteco. Last one is Federal Mogul w/ Permatex Red RTV and still holding on. Plus oil leaks on the mating surface between the engine block and front lower case. Oil weeps down to alternator mounting. New problem: Oil leaking at the oil pressure relief plug (as per the manual).
Simple sealant, teflon etc. ba ang solusyon or something is wrong sa lubrication system? can't afford for now na tanggalin lahat ng parts. pati oil sump tatanggalin. awww
Tesla Philippines
