Results 5,411 to 5,420 of 6552
April 4th, 2018 09:17 PM #5411
Well, those guys from casa refused to use fully synthetic oil to my 20 year old vehicle. They said that they had a report about it saying the oil couldn't adhere much to the cylinder wall. They said that being an old car, the spaces in between are "much larger" compared when it was new. I really don't know, I just followed their advice. There is no way for me to measure the inside diameter of the cylinder and compare it with the piston diameter
Going back to the inquiry earlier. The oil they are using now is ECT 0W-30. 5W-30 is phased out, according to them.
- Jul 2016
- 237
April 4th, 2018 09:35 PM #5412
April 4th, 2018 10:07 PM #5413
Then perhaps there wasn't available synthetic oil with the correct viscosity that will match will the old car when I inquired about it. Saving himself about explaining what the numbers stand for, he simply said that I just use mineral oil. Again, I really don't know.
Thank you for clearing this up.
April 4th, 2018 10:56 PM #5414
April 4th, 2018 11:38 PM #5415
Because that oil is primarily for gasoline engines. It can be applied to Diesel engines that can take CF oils. It's the same deal with Toyota's Full-Synth oil. It's also SN/CF, that's why I decided to stay away from it (I have a Diesel).
It's basically harder to make an oil that can satisfy the highest API rating for both gasoline and Diesel applications in a single bottle. They do exist, though (ie. SN/CJ-4)... just rare, and probably expensive.
Gasoline and Diesel engines produces different by-products during combustion. It is best to use a dedicated oil with the correct API rating that is meant for the type of engine you have (gasoline or Diesel). This guarantees that the supplied additives are sufficient to counter the effects of the engine's combustion by-products.
- Jul 2016
- 237
April 5th, 2018 01:24 AM #5416
April 5th, 2018 02:18 AM #5417
Hindi lang gasoline engine oil, all of shell’s diesel engine oil is up to CF even their highend helix ultra oil.
Mas mura pa ang caltex delo and Zic x7 oils na CJ-4 rating na.
Why would Shell, being one of the largest oil companies in the world not have CJ compliant oils sa helix line?
(Meron sila CK oil sa rotella line na pang heavy duty diesel na mas pang commercial/truck line)
- Jul 2016
- 237
April 5th, 2018 02:28 AM #5418
April 5th, 2018 02:32 AM #5419
- Jul 2016
- 237
April 5th, 2018 03:02 AM #5420That’s the only logical reason I can think of. Didn’t test for a more modern API C certification maybe because they did not see it as a necessity. Besides, they are ACEA B4 compliant. That rating is more or less equivalent to API CH.
ACEA = European
API = American
Tesla Philippines
