Page 194 of 656 FirstFirst ... 94144184190191192193194195196197198204244294 ... LastLast
Results 1,931 to 1,940 of 6552
    Oct 2011
    #1931
    Noted sir. I thought Delo 400 would be much better with the "+" rating for extended oil change interval.
    #1932
    Quote Originally Posted by johnjoseph View Post
    800 ppm na lang yata ang zinc ng CI-4+ Delo 400, mas lower pa di ang CJ-4 Delo 400 LE, Euro 4 compliant para sa ULSD fuel vehhicles with DPF. Hindi na maganda para sa old gas engines, less wear protection.
    Sent from my Light using Tsikot Forums Mobile App mobile app
    1480ppm ang zinc nang delo 400. Sa viscosity index siya mababa vs dgu kaya much better for gas engines talaga dgu inho.
    Sent from my Lenovo using Tapatalk 2
    Aug 2013
    #1933
    Di ba pag API CI-4+/SM, CJ-4/SN, puro environment friendly na, low SAPPS at ZDDP? DGU have less than 1200 ppm zinc content, how come na maging 1480 ppm ang zinc ng Delo 400? CMIIW, zinc ang binabawasan para hindi masira in the long run ang cat con, egr, dpf and other ecs ng new model engines.
    May 2010
    #1934
    Guys, pa-advise ng magandang oil for lancer mx 2004.. Give me some choices, to check if available kay suking auto shop. The cheaper the better... Ako kase magbabayad for my sister.. Hehhehe.. Thank you! ;)
    Posted via Tsikot Mobile App
    Aug 2013
    #1935
    [QUOTE=romeocharlie;2289634]Guys, pa-advise ng magandang oil for lancer mx 2004.. Give me some choices, to check if available kay suking auto shop. The cheaper the better... Ako kase magbabayad for my sister.. Hehhehe.. Thank you! ;)
    Cmiiw, meron na cat con ang car mo. Try mo Caltex DGU or Mobil Delvac MX, both SAE 15w40, priced around Php230/liter, Korean oils Zic Up or Zic A, both SAE 10w40 priced around Php185/liter, all are cat con friendly and with high wear protection additives.
    Aug 2010
    #1936
    what can you say about this oil:
    delo 400
    petron revx all terrain
    royal purple 15w40
    for diesel engine po
    Oct 2011
    #1937
    Delo 400 - CI-4+ good oil for extended OCI.
    Petron RevX - no data sheet
    RP - good synthetic oil.
    May 2010
    #1938
    I thinking of using Petron RevX Trekker on all my old model gas fed cars.
    I used it in my scooter and my bros car which is an Altis G, ok naman.
    May 2010
    #1939
    diba CH4 lang ang delo?
    Aug 2011
    #1940
    Quote Originally Posted by SiRbossR View Post
    delo gold CH4.
    delo 400 CI4+
    delo gold ultra CI4.
    Sent from my ALCATEL ONE TOUCH 5020E using Tapatalk
Mineral , semi synthetic or fully synthetic?
