Results 1,931 to 1,940 of 6552
December 27th, 2013 03:10 PM #1931
Noted sir. I thought Delo 400 would be much better with the "+" rating for extended oil change interval.
December 27th, 2013 03:11 PM #1932
Fasten your seatbelt! Or else...Driven To Thrill!
December 29th, 2013 12:21 PM #1933
Di ba pag API CI-4+/SM, CJ-4/SN, puro environment friendly na, low SAPPS at ZDDP? DGU have less than 1200 ppm zinc content, how come na maging 1480 ppm ang zinc ng Delo 400? CMIIW, zinc ang binabawasan para hindi masira in the long run ang cat con, egr, dpf and other ecs ng new model engines.
Sent from my Light using Tsikot Forums Mobile App mobile app
January 5th, 2014 11:24 PM #1934
Guys, pa-advise ng magandang oil for lancer mx 2004.. Give me some choices, to check if available kay suking auto shop. The cheaper the better... Ako kase magbabayad for my sister.. Hehhehe.. Thank you! ;)
Posted via Tsikot Mobile App
January 6th, 2014 09:24 AM #1935
[QUOTE=romeocharlie;2289634]Guys, pa-advise ng magandang oil for lancer mx 2004.. Give me some choices, to check if available kay suking auto shop. The cheaper the better... Ako kase magbabayad for my sister.. Hehhehe.. Thank you! ;)
Cmiiw, meron na cat con ang car mo. Try mo Caltex DGU or Mobil Delvac MX, both SAE 15w40, priced around Php230/liter, Korean oils Zic Up or Zic A, both SAE 10w40 priced around Php185/liter, all are cat con friendly and with high wear protection additives.
- Aug 2010
- 278
January 17th, 2014 11:20 PM #1936what can you say about this oil:
delo 400
petron revx all terrain
royal purple 15w40
for diesel engine po
January 18th, 2014 12:02 AM #1937
Delo 400 - CI-4+ good oil for extended OCI.
Petron RevX - no data sheet
RP - good synthetic oil.
January 18th, 2014 02:45 AM #1938
I thinking of using Petron RevX Trekker on all my old model gas fed cars.
I used it in my scooter and my bros car which is an Altis G, ok naman.
- Aug 2011
- 336
January 18th, 2014 07:42 AM #1940
Tesla Philippines
