Results 1 to 10 of 21
August 20th, 2009 04:45 PM #1
This might be far fetched but I might as well mention it. This symptom showed up on our Lancer GLXi more than a decade ago. Prior to this, a mechanic removed the thermostat (due to it being stucked up closed). When the engine is cold, you really have to step on the gas pedal to keep the engine from stalling. You have to do this for several minutes because without the thermostat, it takes longer for the engine to warm up and the RPM to stabilize. Once the engine has warmed up, everything remains normal until the next cold start. Putting in a new thermostat solved the problem.
August 20th, 2009 05:38 PM #2
If your engine is EFI .How long did you clean your MAF Sensor, IACV idle air control valve , Throttle body for long time carbon build up. This is also part of basic maintanance to make your idle in proper order. Just my suggestion.
- Aug 2008
- 19
August 27th, 2009 03:50 AM #3i already cleaned up my TB using carb cleaner pero ganon pa din, re: map sensor medyo tunaw na yung lower part.
- Oct 2005
- 64
August 31st, 2009 12:28 PM #4
- Aug 2008
- 19
September 12th, 2009 07:09 AM #5
- Aug 2008
- 19
September 12th, 2009 07:50 AM #6in addition pala, kapag umaandar nako and lets say nag nuetral nako yung rpm ko ang taas mga 1.3k rpm parang nagstuck up so need ko pa mag rev ng once or twice para bumalik sa normal idling w/c is 800rpm. it all started nung nagspray ako ng carb cleaner sa TB ko.
- Oct 2005
- 64
September 12th, 2009 12:34 PM #7malamang nag iistuckup yung idle servo mo eto yun ISCV. baka naninikit na sa dumi. Pwed naman i DIY yan kahit hindi mo idosmantle. Sa hose mo bugahan ok na yan mga 5 shorts sprays lang yun ng carb cleaner
- Sep 2009
- 3
September 15th, 2009 02:55 AM #8zero kaya mo yan dismantle just be carefull to pull out the gasket sa Trottle body at sa cold start valve un yung my dalawang rubber hose galing sa cylinder head panigurado ko kong hindi ka nagamit ng coolant maraming dumi yan at ganun din ang Idle air control valve(IACV) sigurado maraming carbon build up yan I recommend na ang gamitin mong carb cleaner ay yung 3M na kulay white sa handyman ka bumili kong hindi mo lilinisin yan dyan na magsisimula na humina ang batak at lalakas sa gas at ang worst pa nyan baka masira ang ECU mo kasi hindi makakapagbigay ng magandang signal sa ECU ang IACV kaya ang maapektuhan ay ang parts sa loob ng ECU. SAna makatulong sa yo.
- Apr 2024
- 25
May 29th, 2024 08:57 AM #9
- 53,883
Tesla Philippines
