Results 1 to 6 of 6
    Feb 2017
    Nasa tamang level parin po ba ako?
    Tama ba na hindi naman daw dumihin ang ATF kaya ok lang 100k pa palitan?
    ^ ideally dapat every 40k kms ang pagpalit ng atf
    Anong car yan? Nasa manual yan kung ila km ka bago palit atf, modern car nasa 80k-140k bago palit atf
    Sent from my SM-A720F using Tapatalk
    It is standard to change ATF every 40k kilometers
    Dec 2017
    I'm not sure if it is printed on Mazda's manual when the ATF should be replaced. However, I think I will follow my old practice of changing it every 40,000 km.
    Jan 2008
    madalas naka indicate sa manual na "no need to change ATF" if driving under normal conditions.
    kung under "severe" which includes city traffic, long idling, bumpy road conditions, short trips. need to change ATF. some manufacturers recommend to change at 40K kms, some suggest to change at 90k kms.
Pahelp ATF fluid check
