Attachment 8046
ito po ung DENSO IDLE UP ng toyota, sencya na medyo madumi engine bay kci galing biyahe. KHAOS disable ko muna kci pagawa pa ako ng T-connector...medyo ok din po kci from subic to hundred island via Zambales almost 400kms round trip 1200 ang gas(34.95/ltr)ko.
Attachment 8045
eto po ung connection nya. ung positive is connected to the compressor relay then negative sa body. kinulang ako ng T-connector and tube kya ung tube galing sa cylinder head to air filter wla.
HYPER: as per my mechanic, IDLE UP controls your IDLE so your RPM will go back to normal 700-800 pag open AC. and about the tik sound po it means nag OFF or ON po ung compressor. ung akin direct ung FAN ko so hindi cya namamatay pag nag-off compressor. di pa po ako OH eversince and never get to 1/2 ung temp ko.
mga sir, based lang po ito sa experience ko....
