Page 1 of 2 12 LastLast
Results 1 to 10 of 24
    tsikoteers, help naman.
    may dad's 94 accord nagiidle up every time you shift gears.pinalinis na throttle body. hindi na namin malaman kung bakit ganon.
    thanks sa mga magreply...
    Jan 2008
    Quote Originally Posted by archie123456789 View Post
    Automatic transmission or Manual transmission?? give more details or observation reagarding the problem
    m/t po yung accord 94.
    ganito po yung nangyayari, from 1st gear to 2nd gear habang shifting ngrerev up your engine. example... kung shift at 2500 rpm, shoot up sa 2700 rpm while shifting (not stepping on the gas). same goes with 2nd to 3rd and so...
    thanks po sa magreply...
    Nov 2003
    just the throttle or even the manifold and iacv?
    sir speedy, yung throttle lang po yung pinalinis...
    would a dirty manifold and/or iacv be the culprit?
    Nov 2003
    the iacv yes. the intake manifold won't affect i pero magdudumi ulit agad yung tb and iacv if hindi mo isabay sa cleaning.
    May 2007
    Sounds like your Throttle cable sticking. Clean or replace a new one.
    Sir archie123456789 tanong ko lang po kung nafix niyo itong problem na ito and ano po ang ginawa para maayos? I have a gen2 crv and I also have the same problem.
    Sir Speedyfix is this normal?
    Apr 2004
    mrbogus3000,
    manual tranny ung gen2 crv mo noh? same tayo, tumataas ung rpm pagshift to higher gear. pero i did notice kung abot ng 3000rpm before shifting, di cya ganun
    Quote Originally Posted by redpitz View Post
    mrbogus3000,
    Redpitz,
    Oo bro manual tranny yung sakin. Hindi naman ako umaabot 3000rpm. lets say shift ako nang gear nasa 1500rpm when i step on the clutch taas siya nang 1700 or 1900rpm. also pag pababa ang road tapos nag rolling lang ako taas din siya. pero once I turn on the aircon wala naman akong ganitong problem.
    yung sayo ba napacheck mo na? normal lang ba ito?
idle up sa shifting
