Results 1 to 10 of 41
- Sep 2007
- 174
February 24th, 2009 05:59 AM #1If we compare the durability of the old school diesel injectors with the CRDI
injectors like the D4D, DID, do we find them similar?
My old 1992 L200 is still running strong this 17 years with only one time replacement of nozzles after 10 years.
I just wonder how long these modern CRDI injectors last.
It would be good to hear from those who got the first vehicles with crdi when these arrived in our Philippine shores.
February 24th, 2009 09:48 AM #2
Tatagal din but shorter than those mechanical type.
Sa CRDi fuel system, critical ang injectors they have a big and demanding responsiblity.
Above normal temperature and compression may expand the tips of the injector from what i see dito sa shop.
Central Diesel 4113711 to 13Last edited by 4JGtootsie; February 24th, 2009 at 09:58 AM.
February 24th, 2009 10:02 AM #3
TUBIG and fuel impurities are the main kalaban ng CRDI system. Really makes you think of our fuel quality where lack of legislative standards make it of low quality compare to international and even neighboring countries.
And because of the high pressure system, it may not last as long as the mechanical types.Last edited by Gerbo; February 24th, 2009 at 10:14 AM.
February 24th, 2009 10:25 AM #4
All has been well said by both gentlemen above
Just to add as per experience. Our family has 2 units of a modern crdi engine. They are of the same age (2 and 1/2 years). Each unit gets its fuel from different gas stations. The first unit has very corroded injectors and have been replaced by the dealer. The other one still fairs better to this day.
Water is indeed an injector's worst enemy.
February 24th, 2009 02:31 PM #5
February 24th, 2009 02:41 PM #6
Ask kung saan gas station ang may corroded injectors.
Oem will only honor factory defect and not failure due to corrosion.
February 24th, 2009 02:46 PM #7
Di yata sa unit... more likely sa fuel station mismo.
Take this as an example... maraming horror stories from certain areas regarding Toyota fuel pump failures... but I personally know four or five D4D owners at or around 100,000 kilometers with no problems.
I've never had problems with test units... ever... but I filled up once at a provincial station that I'd never used before and got one test unit into limp mode, from water contamination.
It's all about your local stations. Nakakainis lang, nobody is enforcing fuel quality standards here. Heck, even the gasoline in some brand-name stations is suspect!
February 24th, 2009 02:59 PM #8
so even if water contamination from the fuel per se is the culprit, does that mean the water separator function of the fuel filter is not up to the job?
February 24th, 2009 04:33 PM #9
Unit is a 2006 Innova. Water separator's effectiveness in this case? I really don't know. Here's some good reference about diesel fuel filters:
http://www.filtercouncil.org/techdat...dieselfuel.htm
The last part is especially interesting. It's about alcohol based additives.
February 25th, 2009 01:46 PM #10
Too much water = clogged water separator = clogged filter = fuel pump burnout / possible fuel injector starvation = big repair bills, either way.
