Results 141 to 150 of 150
- Feb 2014
- 2,658
November 22nd, 2018 01:22 PM #141LOL. taga tulak ng Pertua yan. even in the facebook groups there are lots of people trying to promote pertua. i.e. click farm
- Sep 2007
- 612
January 13th, 2019 11:12 PM #142Logically i believe it will be the effect. I believed pertua is a thickening oil additives... Thats why it makes engine silent.. More cushion on metal to metal contacts. And i beleived it will improve power and consumption on worn out engine. Bec it might lessen the big tolerances from worn out parts... But for new engine especially now... The tolerances has improved a lot thru computer machineries... Such that the manufacturer recommends thinner oil on both gas and diesel engine.. My nv350 and montero recommends 5w 30... Even my motorcycle does... When the oil is thick it will be silent bec of cushioning.. But it will be less power and less efficient... Mabigat icirculate ang heavy oil than thinner oil... :sometimes the pertua agent are so dissapointing... Giving false info regarding their product...i was dissapointed when they say its ok to put in in wet clutch bike... Which manufacturer warns against friction modifier that might result i clutch slippage... They dont know what wet clutch is... And for those who is notknowledable about their bike or cars may end up a disaster...
January 13th, 2019 11:35 PM #143
- Sep 2007
- 612
January 13th, 2019 11:36 PM #144I believe in new engine pertua does not help.. But rather harm if it makes your oil thicker... It might have oil starvation on very tight tolerance parts...
My understanding of multigrade oil is that the base oil the true viscosity of the oil... It adds V. I. OR VISCOSITY IMPROVER... to make it performs thicker when the oil is hot... And the one that degrades due usage is the v. I. That means a 5w40.. Will become 5w30.. 5w20... Until it willreturn to 5.... The sludge eventually build up because the oil is damaged by foreign chemical reaction such as condensation of burning fuels... Impurities of air... As well as impurities of oil are burned up...
This where f synthetic oil advantage of... Oil impurities are lesser because of distilling... Hydrocracking to such molecules are linear than mineral... This process is has more durable
V. I... It is morw tolerant to heat and shear
A good thin oil is better... Because oil will circualte much faster in cold start up... Thats the highest
Engine wear we could get... Actually when the engine is in good condition the metal to metal contact is almost non existance...
Due to the oil film that lies between two engine parts... Like water on the road causes hyroplaning on our tires..
- Sep 2007
- 612
January 13th, 2019 11:49 PM #145V. I. Is always present on all multigrade oil
Im not sure if pertua is v. I .... But if it makes the engine silent then it makes the oil thicker... And if it is a friction modifier..it might cause problems on wet clutches
Adding pertua to used oil is much more persuading than adding to new oil if it is a v. I. Because its replenish thw used oil v. I..... But adding to the new oil might cause unpleasant and unregulated oil viscosity... It might exceed your viscosity requirements during its operating temp and might cause oil starvation on parts that have very low tolerances..
If it claims to cling on the metal then that is good for engine in start up situation thus prolong its life... Because we all know that cold starting is the one that shorten engine life
January 13th, 2019 11:51 PM #146
toyota and other manufacturers already did the lubrication reseaech.. no need to guess engineer guess oil analysis. follow their oil change intervals.
- May 2004
- 65
- Sep 2007
- 612
January 14th, 2019 06:26 AM #148
- Sep 2007
- 612
January 14th, 2019 06:28 AM #149
January 14th, 2019 11:33 AM #150
