Results 11 to 20 of 25
    Jun 2006
    yung getz ko po ganun din...
    may sensor kasi sakin sa panel kapag malamig ang makina...pag may ganun nagiging mga 1500 rpm yung akin hanggang magsettle sa 800-900 idling nya.
    sa gli bigbody nasa mga 1.5k lang. For how long should the Fast Idle Start ba lasts or does is it based on your engine temperature?
    Nov 2003
    a couple of seconds lang dapat mataas. at most 30 seconds.
    May 2010
    similar problem din po sakin pero ang pagkakaiba, ung idling ko e permanent na nasa around 1.3krpm. ok lang po ba un? dati po kasi 1krpm lang.
    Apr 2024
    Quote Originally Posted by butchokuy View Post
    hi mga gurus,
    tanun ko lng.. nu kya problem ng car ko - lancer glxi 93
    pag start ako, ang taas ng idle nya mga nsa 3K RPM, stay sya dun ng ilang sec then bumababa dahan-dahan hanggang s 1K.
    after nun, normal na kahit s trapik or nka-stop.
    bagong palit lng ng servo neto.
    many thanks in advance,
    Normal po Yan saken inde bababa need pa re start everybody can share same as my experience so I have an idea what part need to be replaced
    Apr 2024
    In my car idle on coldstart was 2k high need 2 to3 mins to be restarted the engine to get the normal idle can anyone encountered same as my experience any idea what part to be replaced
    Apr 2024
    Quote Originally Posted by papavi View Post
    Saken sir Minsan NASA 2k stable mga 2to3 minutes mag up and down need pa re start para maging normal idling
    Apr 2024
    Quote Originally Posted by speedyfix View Post
    try adjusting the throttle body...
    Jun 2011
    Quote Originally Posted by Rjmar View Post
    Puwede i try,
    1. Palit air filter
    2. Linis throttle body
    3. Linis MAF sensor
    4. Check spark plugs or ignition coils
    there's this youtube article, about a 2000s altis, that had a high rpm on cold start (2000+ daw), that only gradually went down to sub-1000...
    sabi niya, may leak na raw ang intake manifold.
    fixing it is the solution, daw.
    our 2003 altis, had a high cold start rpm of only 1500...
high idle RPM at engine start
