Results 1 to 10 of 10
- Sep 2012
- 6
September 3rd, 2012 04:24 PM #1Hi All,
Need expert advise mga sir. My ae92 just had engine overhauled and replaced carb (replacement only). Problem is, during idle grabe ang sinok sa pipe, i had the fuel filter, fuel pump, air filter replaced. Plugs are new, distributor cap, high tension wires. The odd thing nawawala ang sinok pag on ng A/C. I can tell na meron pa rin but its completely tolerable unlike pag naka idle. Pls help. Car is running stock 4af engine.
- Jun 2010
- 321
September 3rd, 2012 05:38 PM #2pa tune mo yung carb, try mo pihit yung pang adjust ng air and fuel ratio......... ganyan din kasi yung feroza ko, pihit2 ko lang yun hangan makuha ang tamang mixture, pero dapat nasa tamang operating temp. ang engine before mo pihit
- Sep 2012
- 6
- Jun 2005
- 3,774
September 3rd, 2012 06:23 PM #4carb problem yan. patune up mo. bakit ka pala nagpalit ng carb? nasan na yung luma?
- Sep 2012
- 6
September 3rd, 2012 08:31 PM #5Sir sirkosero,
Due to erratic idle po and the same hiccups issue. The old one has a busted butterfly na po. The hiccups issue was gone for a month or so and just returned for some reason after the replacement unit was installed. Thanks ng marami sa reply. Any inputs is greatly appreiated mga sir.
September 3rd, 2012 09:49 PM #6
is the hiccuping or misfire random or does it have a regular pattern? maybe your fuel is contaminated with water. if you just had the engine "overhauled" have the shop do a compression test and engine idle vacuum and engine cranking vacuum checked. there might be something the "mechanic" missed.
- Sep 2012
- 6
September 4th, 2012 09:23 AM #7
- Jun 2005
- 3,774
September 4th, 2012 10:24 AM #8sounds definetly like a carb problem. if you have the old carb, il bring that to kamuning for an overhaul and some repairs. id also use a repair kit.and let then do the tune up.
kumg wala na yung orig, i'd have the replacement checked as well.
i frequent m2m kamuning although there are some bad experiences but i find them to be the most honest.
- Sep 2012
- 6
September 4th, 2012 10:29 AM #9
- Jun 2005
- 3,774
September 4th, 2012 10:29 AM #10sounds definetly like a carb problem. if you have the old carb, il bring that to kamuning for an overhaul and some repairs. id also use a repair kit.and let then do the tune up.
