Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
    Jun 2005
    #21
    You have to consider another vital job of an engine oil, which is to suspend combustion by-products using detergents. Gasoline and Doesel engines produces vastly different by-products. It then follows that the wrong oil can be deteimental to the engine if the detergents within the oil is incompatible with the by-products.
    Source: Can I Use Diesel Oil in My Gas Engine?
    Thats is why you shouldnt just use any diesel oil.
    If you want to use diesel oils, check the label kung labeled sya for gas engines. Usually yung may tatak na SL tapos may diesel rating din na CI(etc)
    Jan 2009
    #22
    Quote Originally Posted by sirkosero View Post
    That's what I said several posts back. My last post above is to address the misconception that Diesel oil is better for gasoline engines because of their detergent properties.
    Jun 2005
    #23
    ^my bad. Didnt realize you're the one who commented a few pages back.
    Jan 2009
    #24
    Sorry, didn't mean to snap at you. With forum replies, sometimes the wrong emotions are inadvertently conveyed.
    May 2009
    #25
    Quote Originally Posted by allan-kurt View Post
    Wag kana mag reply boss kung di ka rin makaka tulong sa katanungan ko.
    k fine..........
    chill ka lang. inom ka muna pilsen.
    Jun 2012
    #26
    Para wala kang agam-agam ika nga? Pa drain mo na lang.
Help - Diesel engine oil in petrol car
