Results 1 to 10 of 13
- Feb 2006
- 771
December 27th, 2008 11:00 AM #1hi bros,
need urgent help from you ,
yung ride ko po kasi e iniwan namin ng almost 2 months n naktigil dahil sa umalis ko ng pinas ,tpos kanina umagas try ko andar ok nmn start agad ,problem is nung tapak ko clutch ,ayaw mag engage bale anlambot lambot tlaga ,wla resistance kahit anong pump ko ng pedal ayaw p rin!restart ko sya how manytimes ayaw.
baka kako me nagfail na part kaso di ko madetermine ano checkin e,
pls help po di kami makaalis bahay nito.hahahhaa
ride popala is 7G galant , itry to check the fluid pero nasa below the max line pa naman e.
December 27th, 2008 01:17 PM #2
try to pump your clutch pedal several times muna. baka natuyo yung lines.
try to check also the fluid.
- Sep 2008
- 3
January 1st, 2009 11:46 AM #3sir bout sa clutch problem mo mdali lang po yan,,pump mo lng ng pump yung clutch tas,pag wala tlga bleed mo sguro alm mo nman po kung sa bleed yan.
January 1st, 2009 11:53 AM #4
Pump it and see if no fluid escapes.
You can bleed it. We bled a 7G Galant at the parking lot dati because of similar symptoms. The owner was able to drive home after.
January 2nd, 2009 09:26 AM #5
If this is setup as a hydraulic clutch, then either the slave cylinder is bad, or the master cylinder to the clutch system is bad. If cable, then the cable seized up, and could've fell out of its holder, or quadrant, under the dash. But I figure its hydraulic.
Check the clutch master cylinder. Open it up and check if there is any fluid in it. If there is, you probably have trapped air in the line. Get a good manual for instructions on how to bleed the system. Again, check your clutch system for abnormality.
- Feb 2006
- 771
January 4th, 2009 12:10 AM #6thanx po mga sirs,
hehehehe try ko po pump sya before kaso ayaw e nung try ko say bleed bigla nagkaroon ng resistance yung clutch and i was able to move the car hahahhaa
thanx po mga sir
January 4th, 2009 12:24 AM #7
Yup. It's a good band-aid fix. But don't go on a long trip yet without having had the clutch cylinder fully checked. Sometimes a repair kit will work if only the rubber is worn and the shaft is still flawless.
- Feb 2008
- 577
January 4th, 2009 09:03 AM #8how would you know if you have a faulty master cylinder? sa secondary kasi madali makita ang leak. what about the master?
January 7th, 2009 03:11 AM #9
If the brakes don't stop easily in that case, suspect a problem with your vacuum aided power brake booster. If the master cylinder (driver's side firewall) is full of brake fluid and there's no visible fluid leaks in the wheels or brake lines and the pedal goes to the floor gradually, you probably have a bad master cylinder if there's no reason to believe the brakes need bleeding or any rear drum type brakes are properly adjusted if recently installed.
- Feb 2008
- 577
January 7th, 2009 08:04 AM #10
Tesla Philippines
