Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
    Jul 2012
    Yung pang 3 po na fuel injector niya mukhang my sira na that causes the engine to vibrate, na test ko siya kasi kapag tinatanggal yung cable niya hindi ngbabago ang engine while yung iba ngbabago. So pinalitan po namin ang fuel injector but still the vibration persist, and hindi padin gumagana. I Think electrical na problem at hindi ang fuel injector. Tingin niyo?
    My naka experience na po ba neto?
    Jul 2012
    Quote Originally Posted by jodski View Post
    When was the last time napalitan ang engine support nyan?
    Nung pinatignan mo ba naka lifter yung car para ma inspect properly yunf engine support? Konting crack lang kasi nyan or isa lang dyan malambot na mag vibrate talaga yan.
    For all others nalista na ni Glenn
    Sent via Tapatalk
    Boss, last week lang din. Yes tinaas po siya.
    Jun 2011
    Quote Originally Posted by anakngsultan View Post
    Baka naman high tension wire ang kailangan Mong palitAn...
    Jul 2012
    Not familiar with tension wire boss, para san po ba yun?
    Jun 2011
    YuNg tinangal Nyo Sir na cable-- na nakakabit sa spark plugs..
    Jun 2011
    Does your system have any or combination of PO300, PO301, PO302, PO300 and/or PO304?
    Feb 2009
    Is the check engine lit with them engine running?
    normal lang ba na mag-vibrate talaga yung 3-cylinder engines?
    Feb 2009
    Quote Originally Posted by eon red View Post
    Normal to some extent. If the idle speed is lower than specs it gets worse.
    Feb 2009
    Smart phone decides to send codes[emoji89]
Help : Car Vibration
