Page 1 of 2 12 LastLast
Results 1 to 10 of 18
    Apr 2009
    Na observe ko after changing my oil from 20w50 to 10w40 and also from bosch platinum spark plugs to OEM spark plugs, fuel consumption ko naging 5km/liter na lang. bago din naman ang air filter. car is 1997 corolla 1.6 gli with 123k mileage. Ano kaya ang problem?
    Jul 2015
    Quote Originally Posted by bail View Post
    ilan ba dati? 6? if its an AT, better chk the tranny fluid...
    Apr 2009
    dati is 8km per liter. manual transmission
    other symptoms?
    Jun 2011
    Check tire pressure..
    Aircon compressor bearing/ pulley bearing
    Rear brakes/ Handbrake cable
    Check for fuel leaks
    Check- aircon aux fan/and condenser...
    Check your car aircon for high pressure
    And Balik mo lahat ng ginagawa or pinalitan mo dati...like oil.. spark plus etx.
    Mar 2004
    Maybe engine needs a tune up? ...
    Aug 2013
    kung humina hatak ng makina sir, possible nabawasan compression dahil sa mas manipis na oil na ginamit kaya lumakas fuel consumption.
    Apr 2012
    Quote Originally Posted by innova2013 View Post
    maybe its the other way around. baka gumanda hatak ng makina since manipis oil na ginamit kaya naging mas aggressive driving style ni TS at tumaas fc
    seriously, TS just get back to the old oil and spark plugs. using thinner viscosity oil may not be that good to a 20 year old engine seals..
    Long shot, - sparks bro.
    One of our rides was doing 8km/L for a long time.
    I changed spark plugs.. went down to 7Km/L
    Check mo dipstick kung nababawasan ng langis or check mo tambutso kung meron na kaunting usok lali na pag dinidiinan yung gas pedal. Pag positive pareho ang dahilan nyan ay yung paggamit mo ng manipis na langis. Dahil medyo luma na, maluwag na yung mga piston ring at sumusuot na yung langis sa compression chamber. Kasama na sya nasusunog dun at hindi na tuloy maganda and air-fuel mixture kaya mababa na efficiency ng makina.
Fuel Consumption is 5km/liter
