Results 11 to 17 of 17
- Oct 2016
- 3
December 27th, 2016 07:47 PM #11
December 27th, 2016 07:57 PM #12
sounds like your mechanic is trying "catch all" guesses hoping to "fix" the symptoms. look for a competent technician. sure you might need a minor tune up (ignition secondary tune up) and air filter change. but it sure sounds like he is a typical "mechanic", does not really know what is happening and experimenting by replacing parts at your expense
December 27th, 2016 08:09 PM #13
during the vietnam war, it was called carpet bombing (just bomb the hell out of them) because it was too long and costly to seek out the NVA, now, it is the "smart bomb" with pinpoint accuracy (bomb thru your bathroom window). no more guesses and shotgun symptom shootout of the symptom. just get it done with the least cost and least disruption
- Oct 2016
- 3
December 28th, 2016 01:42 PM #14
December 28th, 2016 03:56 PM #15
Measure the engine intake vacuum both cold and normal operating temperature. If you can, have a printout of the PCM parameter readins and post it here.
December 28th, 2016 05:20 PM #16
RAV$ nang cousin ko dtai may ganyan ding symptoms. Yung problem pala is the thermostat. Hindi umiinit agad so reading nang ECU eh dapat kunti lang gas ipump kasi hindi pa mainit makina. Toyota casa gumawa nun. Minsan din sa airflow nga, may sensor dyan na kapag sira or barado, erratic din ang idling.
March 21st, 2017 08:09 PM #17
If walang CEL, mechanical ang issue. I would try sa pinaka-madali... from spark plugs, fuel filter, fuel pump, fuel pressure regulator, etc. Mas madali sana if naka CEL.
Tesla Philippines
