Results 1 to 10 of 11
May 22nd, 2007 03:13 PM #1
peeps.. im a newbie here.. i just bought a used civic ESi and i recently had its timing belt and tensioner changed for PMS. a reputable mechanic ( who btw has been the resident mechanic of my dad since i was 10 years old - im 24 now) worked on installing the new belt. after finishing the job and firing the ignition up, the engine wont start. we've tried charging the battery, thinking that it might have been discharged coz of the worklamp - didn't do crap. so we also used another battery - didnt do crap either. now im stuck with a car in our garage on a rainy season. the mechanic told me that the ignition coil gave up and im forced to buy a new one which would probably cost around 2K. its so frustrating since the car was VERY reliable before i had the belt changed. starts in one click, fuel efficient, and gets me from point A to point B. i guess this is what i get for not letting speedyfix work on it instead..
so my question is, do you guys think the mechanic is right about changing the ignition coil? thanks in advance... more power to tsikot...
May 22nd, 2007 03:33 PM #2
did the mechanic use a timing light to properly set the timing belt? baka basta nalang pinalitan without properly using a timing light.
although i dont know if that has something to do with the car not starting.
- Jun 2004
- 1,311
May 22nd, 2007 03:45 PM #3Did the engine at least crank?
If yes, possible nga na ignition coil, replacement should cost less thank 1k
May 22nd, 2007 03:50 PM #4
i dont think he used a timing light.. he just made sure that the crankshaft had its TDC at the right place. i've read honda's user manual, and that's the same procedure shown. may i ask what a timing light is anyway? thnx...
May 22nd, 2007 03:56 PM #5
yes, the engine cranks when you click the ignition but it wont start.. where's this store that sells less than 1K for that ignition coil? dalawang strores na kse napagtanungan ko.. Alabang auto parts (sells OEM honda parts cheaper than CASA) - P1800, and the other one is that store in EDSA cor rotonda - P1650...
May 22nd, 2007 04:48 PM #6
maaring hindi ng siya nakagamit ng timing light kasi hindi pa ng nag start ang makina, at gagamitin lang ito pag tumatakbo na at iaadjust ang timing,
saan ka ba nakalocate meron akong trusted mechanic try mo Dick pangalan 09274021675 or 4348474 sa kamias Q,C, likod lang ng fuji parts supply, for parts piyeza 8734084, G&S 9218831, fuji 9215408, pemview 4102873, partstar 5110446, carpower 8318558.
May 22nd, 2007 11:49 PM #7
timing light is used in dynamic igntion timing (i.e. while engine is running at idle). changing the belt won't necessitate this procedure as long as the timing marks are aligned and piston #1 (based on firing order) in TDC.the ignition coil is sensitive and may be damaged easily. have the coil checked for continuity using a VMO.
- Jun 2004
- 1,311
May 23rd, 2007 07:59 AM #9I think sa carpower pasay ko nabili yung sakin, pero accord yung sakin, nde ko alam kung mas mura yung pang accord, 900 replacement 1.8k oem. try mo hingi ng discount.
Tsikot Member Rank 5
- Nov 2003
- 3,848
May 27th, 2007 09:17 AM #10it will take less than a minute to check if there is electricity going to the coil.
if he's a good mechanic he should know how to test the coil.
Tesla Philippines
