Page 1 of 3 123 LastLast
Results 1 to 10 of 32
    Oct 2004
    Mazda 323 sedan 93; Paghirap yon makina tumutunog ng "takatak-katak" parang ganun, lala pagpinilit ko apakn yon gas pedal. Pagtumakbo sa highway minsan myron parin tunog. Patulong naman pano ang gagawin dito. tnx.
    hmmmm... hindi kaya tok tok na ang sound? ano bang RON ng gas mo?
    Oct 2004
    sir, parang typewriter pag tumunog...
    ganyan din sa akin lalo na kapag pa-akyat yung kalye.... pero sandali lang. nawawala agad.
    Oct 2004
    may solution ba iyo? or ganito talaga mag old n kotse. Na-adjust ko na distributor advance and downgrade. Pag-downgrade mo naman wala sa timing mamatayan ng makina. So I turn it back to the original setting.
    Quote Originally Posted by eagle
    mas maganda siguro kung pa-tune up mo na lang bro para wala ka nang alalahanin.
    ah pag ganyan ala na ako idea... try logon to http://www.protegetech.org/
    Oct 2005
    pre...try using gasoline with higher octane value...baka mawala...
    sa distributor ang ingay na yan. ganyan din sa akin. yung takatak sa mismong harapan ng driver side galing. kung luma na yung distributor cap nyo its time to change it. isama na nyo palitan ang contact point at condenser.
    Aug 2003
    on the other hand is that a DOHC engine? some 323's have SOHC B6 and others have DOHC. the 323 DOHC B6 engine has hydraulic lash adjusters (a.k.a. lifters) and the typewriter sound is very common. it's only cosmetic (doesn't cause damage or reduce engine performance) but can be annoying.
engine "takatak-katak" sounds while running
