Results 1 to 9 of 9
- May 2007
- 50
June 5th, 2007 10:29 AM #1Hello po. There are threads related to overheating but
Please advise lang po. Kanina pumunta yung pointer ng temperature gauge ng lynx sa "High" (exactly sa H). Logic would suggest na hindi normal (kasi dati po hindi naman lumalagpas sa gitna ng gauge yung pointer) yon but do you already consider that to be overheating? Napansin ko din na nabawasan yung tubig sa reserve tank ko.
I usually don't put coolants in the reserve tank. Is that also a factor? Pero ngayon lang naman nangyari.
Sa ngayon nakapark po at naghihintay lang ako ng response niyo before I drive it home. Pwede pa kaya idrive pauwi? thanks po.
June 5th, 2007 10:36 AM #2
sir the best way is tumawag ka na lang ng mekaniko. kulang kasi detalye na binigay mo. madami kami dapat itanong. pero tama ka. di yan normal. baka kasi yung auxfan mo di gumagana/nagloloko. baka may singaw din hose mo.
kung di naman traffic pwede mo itakbo. bantayan mo lang ang temp. para kung tumaas maitabi mo kagad (hangat maaari sa mga gas station. baka ma tow ka pa). tapos pag start mo ngayon, kung mataas pa din temp mo, wag mo muna pilitin. ipahinga mo pa ng matagal.
June 5th, 2007 10:41 AM #3
it might be your thermostat not opening anymore.
Check mo muna thermostat, ilubog mo sa mainit na tubig you should here a tick sound, kung wala hindi na bumubukas yan, time to replace.
check also the radiator cap, kung okay pa ang lapat.
June 5th, 2007 11:23 AM #4
Coolant in the reservoir is there to compensate for coolant loss. When the temp gets hot it expands, dun napupunta sa coolant reservoir yun. Kaya hindi mo dapat punuin to the brim, just to the "max" level. When the temp gets cooler, coolant from the reservoir goes back into the radiator.
Chances are the car needed the extra coolant, pero since wala kang coolant sa reservoir, wala siyang choice kundi mag overheat. Also, baka since matagal nang walang coolant dun, ngayon lang siya "bumigay"...
June 5th, 2007 12:16 PM #5
pag tumaas and needle mo ay overheat na nga yan. check mo yung water level kung ok pa. kung tumataas pa din ang temp maski ok ang level ng water ay check mo naman yung rad fan kung tumatakbo.... baka nga me sira yung sensor.... ang wag mong kalimutan i check ay baka may leak yung hose mo.
mbeige, meron syang coolant/water reservoir dahil lynx ang kotse nya.
- May 2007
- 50
June 5th, 2007 02:25 PM #6Thank you po sa mga reply. Natsek ko na po yung radiator naubos yung tubig. Nilagyan ko (lhalos isang gallon nga e) na tapos pinaandar ko sasakyan umiikot naman ang tubig sa radiator. Sabi naman ng kaibigan ko baka yung radiator cap ang may sira. Anyway, try ko na rin patsek mamaya sa mechaniko.
Thank you ulit.
June 5th, 2007 03:25 PM #7
June 5th, 2007 04:29 PM #8
yup sure sign ng overheat. happened to me once same situation park ko sa umaga pag pasok ko sa office kita ko ung temp gauge an taas. nung pauwe tried heating up the engine di ko pinaandar tingnan ko lang kung tataas.and tumaas nga. ginawa ko since rush hour trafic d ko muna ginamit nataon may gimick. iniwan ko muna parking lot. then sakto pagkatapos gimik dun ko inuwe mga 1 na un la na trafic. pinaayos ko and and sira is nag stuck up na ung thermostat valve kaya di na nag cicirculate ung tubig at nag crack ung top ng radiator ko.back job pa nga sa honda magalanes un e inayos lang nila ung radiator pero di pinalitan ung thermo. dala ka din ng tubig just in case kelangan mo.
Tsikot Member Rank 5
- Nov 2003
- 3,848
June 10th, 2007 01:33 PM #9the worst thing you can do is force the car to move when it is overheating na.
Tesla Philippines
