Results 1 to 10 of 16
- Sep 2004
- 161
August 14th, 2012 12:06 AM #1hello guys. just wanna ask if these are connected. i've recently checked my engine bay and found out that my oil catch can had some nasty oil sludge around the fittings and i also found out that my coolant reservoir was empty. i had to refill it and had around 1.5 liters for top up at the radiator. are they related... this is the first time that this ever happened to me. im quite anxious...
- Feb 2003
- 1,038
August 14th, 2012 12:19 AM #2Those fittings are just showing that you really needed to have a catch can.
It seems you have lots of oil carry over...the oil stain and accumulated dust is just an indicator that either that metal clamp is loose or you need to put a teflon tape or swag paste over that red fittings threads. The thread may not really be that tight or have gaps on it.
Your coolant depletion doesn't have any correlation to that Oil catch can...totally separate case. Check kung me leak ang radiator and hoses mo. Hope this helps.
August 14th, 2012 09:41 AM #3
try to seal the connections of the hoses with fittings so that the oil vapor gets trap in the catch can and doesn'e escape... yung oil vapor condenses near the fittings and the dirt will be attracted to that kaya dudumi yung sa meh fittings...
as for the coolant, walang correlation yun, mauubos lang laman ng reservoir mo kung meh problem sa cooling system.... very seldom should the reservoir get depleted...
- Sep 2004
- 161
August 14th, 2012 02:04 PM #4Thank you guys. If there's no leak on the cooling system, what could be the problem?
Sent from my iPad using Tapatalk HD
- Sep 2004
- 161
August 16th, 2012 09:10 PM #6
- Sep 2004
- 161
August 19th, 2012 10:34 PM #7Got a busted hose. Thanks for the replies
- Sep 2004
- 161
August 29th, 2012 03:31 PM #9
August 29th, 2012 04:51 PM #10
fuel filter assembly are sold cheap at auto surplus shops. i'll make one this weekend (surplus assy + cheap fuel filter)and see how it fares.
Tesla Philippines
