Results 11 to 20 of 21
- Jul 2015
- 9,583
February 14th, 2017 08:29 PM #11what oil are you using? traffic or smooth sailing?
- Mar 2017
- 6
March 2nd, 2017 10:53 AM #12dpat you should always check the quality of your engine oil. but did you tried using a ENGINE FLUSH? try using it on your 20k PM if you have a brand new car. it removes carbon deposits on your pistons and piston ring crapper and oil sludge.
March 3rd, 2017 01:52 PM #13
from ZIC X7 (FS) to Caltex Delo 400 (MG) ramdam ko difference ng performance.
Dati 10Km ang change oil, top up sa 5K.
Ngayon every 5K changeoil
March 3rd, 2017 02:04 PM #14
March 3rd, 2017 02:15 PM #15
- Aug 2019
- 7
August 20th, 2019 04:38 PM #16Pasensiya na kakasali ko lang dito. Ang katunayan may tanong din ako.
Gaano po kainam ang Valvoline Premium Conventional Oil 10w30 para sa Toyota Vios?
Nakita ko po sa user manual, pwede ang mga sumusunod:
5w30
10w30
15w40 and
20w50
Maraming salamat po sa mga makakapagbigay ng nh sagot ayon sa experience nyo po.
- Aug 2019
- 7
August 20th, 2019 04:46 PM #17Pasensiya na kakasali ko lang dito. Ang katunayan may tanong din ako.
5w30
10w30
15w40 and
20w50
August 20th, 2019 05:01 PM #18
August 20th, 2019 09:12 PM #19
For the older, leaky loved, this quality global bestseller, LiquiMoly MolyGen, can help you trace where your oil is dripping from. Besides being marketed as "The Closest Thing to Zero Friction", this oil comes w/ a UV leak dye, too. And, it's GREEN...literally....& glows under UV light.[emoji4]
- Jul 2019
- 142
October 14th, 2019 02:56 PM #20hi. i don't know of this is the right thread. but if not, please transfer na lang.
My question is that, if i change the oil of my car to synthetic oil, in the next change oil, can i revert back to not synthetic oil? thanks
