Results 1 to 10 of 21
May 7th, 2008 04:09 PM #1
Bakit yung L3 ko pag malamig ang makina ok yung starting, pero kung mainit na tapos e start mo ulit mahina ang ikot ng starter? stater ba o battery.
Tsikot Member Rank 5
- Nov 2003
- 3,848
May 22nd, 2008 09:08 AM #2could be both. pacheck mo charging ng battery and kung malakas naman sya baka starter nga may sira.
May 22nd, 2008 11:22 AM #3
sounds like starter that is going bad. When its cold the starter is fine but when its heat up there are too many electrical resistance and the starter turns the engine over too slow to start the vehicle. When you say Hard To Start over you mean slow cranking...then the starter is the problem, it happen a lot.
May 22nd, 2008 12:30 PM #4
sir parang baligtad ata yung L300 namin dito mahirap iistart pag malamig pero pag uminit 1 click agad sa tingin ko boss starter baka naninikit
or boss baka me grounded?
- Sep 2006
- 1,335
May 23rd, 2008 07:35 AM #6
Right! Its possible that your engine is very hot but you cant see the right temp reading sa gauge.
Parang plancha/iron ang piston at liner pag sobrang mainit naninikit.
What you can do if it happens again is refill the cooling system with colder water, if possible open the radiator's drain plug and replace the water.
If it starts instantly after, it confirms the problem.
- Jun 2006
- 12
May 24th, 2008 12:43 AM #7mga sir. nangyayari rin sa akin yan. kahit na mdyo bago pa battery ko. minsan pag sinubukan i-start parang ayay tumuloy. pag nangyayari sa akin yon, nag aantay ako ng mga 5-10 sec bago ko i-start ulit. tpos ok na. starter kaya problema pag ganon?
May 24th, 2008 07:42 AM #8
It will depend on what you hear during start up.
Pag bendix drive may click pero walang redondo.
Minsan slow motion pero malakas and pitik sa simula.
- Jun 2006
- 12
May 24th, 2008 12:22 PM #9
May 24th, 2008 05:57 PM #10
Do you know whether reduction or regular starter ang nakakabit sa iyo?
Either weak battery or may sayad na yung starter and diagnosis ko.
Tesla Philippines
