Results 1 to 10 of 20
January 19th, 2019 11:47 AM #1
Anyone tried using products like Gumout or CRC intake valve cleaner? I'm nearing 20k Km and I'm thinking of ordering and using the Gumout intake valve cleaner to spray and clean some of the carbon deposits for maintenance. Just want to know if any tried using these kind of products and had issues with it.
BTW the car has gas turbo direct injection.
- 53,883
January 19th, 2019 02:53 PM #2
January 19th, 2019 03:27 PM #3
- Aug 2017
- 321
January 20th, 2019 04:13 PM #4
January 20th, 2019 04:34 PM #5
doc, even if you do the italian tune up on a DI engine. it wont help as the injectors are past the intake valves. Toyotas and some fords have dual injection (port and direct injection)to fixed this issue. while some hyundais&kias have gone back to port injection instead of GDI(direct injection).
January 20th, 2019 04:50 PM #6
That is true. Fuel won't reach the back of the intake valves, therefore there won't be anything to clean it.
The theory behind italian tune up for DI as I recall, is that "supposedly" you run the engine hard long enough so that the engine produces enough heat to melt the carbon deposits off. I'm not entirely convinced that its enough or it even works at all.
January 20th, 2019 05:00 PM #7
January 20th, 2019 07:55 PM #8
- 53,883
January 20th, 2019 09:11 PM #9i don't know.
i've never had our car "cleaned" in any other way.
and as far as i know, the engine still works fine.
what about techron?
January 20th, 2019 09:15 PM #10
