Page 1 of 2 12 LastLast
Results 1 to 10 of 2348
    Sep 2006
    Quote Originally Posted by carbuncle View Post
    ano may ok. pa calibrate o carbon clean? kasi napansin ko.. mas mabilis tumaas rpm ko kaysa sa speedometer. pagumabot na ako ng 100 km/hr... rpm ko is nasa 3.5 dati... nasa 120km/hr 3.5 lang rpm. tama kaya ito? caibration ba needed for this? thanks.
    You don't need carbon clean or pump calibration on your specific complaint. You need to check the accuracy of your speedometer and tachometer. Questions:
    1) Did you change your tires or tire size?
    2) Was clutch work done on your car?
    Mar 2003
    sir dieseldude,
    I have this problem since i acquired my 2002 strada. Sort of a factory defect. The problem is whenever I am traversing a slope ( 10 degrees in my inclinometer), I am losing power especially from a halt. Parang mamatayan ako ng engine. What i do is apply my handbrake and rev my engine up to 2k then let go my handbrake to accelerate. Sabi ng mekaniko ko, kulang daw sa galit ang makina pag nire-rev. Medyo ipina-advance ko ang timing at medyo nakatulong kaso maingay ang makina at malakas sa diesel. what is supposed to be the problem? Thanks in advance.
    Sep 2006
    Quote Originally Posted by mangyan View Post
    sir dieseldude,
    You should have requested Mitsubishi for warranty support when you first noticed this problem. But I guess this is now too late.
    I have the following questions:
    1) Did you increase tire size?
    2) Do you have an automatic transmission, which may not be downshifting to first gear?
    3) Does your engine smoke a lot when you're losing power?
    4) Has anyone tampered with your injection pump's adjustments?
    5) Have you checked your brake adjustments? Brakes could be sticking.
    6) Have you tried replacing your fuel and air filters?
    Your anwsers to these questions may help in diagnosing your problem.
    You can also bring your Strada to us for evaluation. This is free of charge.
    Best regards,
    Dirseldude
    Mar 2007
    good day sir dieseldude,
    inquiry lng po bossing: just acquired a 2ndhand m/t tdic starex w/ 73k odo reading, just recently i noticed emission of black smoke when i rev up frm 2500 beyond. it was newly changed oil, newly replaced air filter- does it has to do with the injection system kaya ganun? ok nman yung hatak nya aftr machange-oil, medyo nagpino nga takbo ng makina saka ramdam pa din yung hataw kpg pumalo sa 2k-2.5k rpm.
    btw, it was casa maintained b4 i got it, as the receipts prove it. napansin ko lng sa 50000 & 60000 pms nkalagay sa receipt: SST applied to adjust injection pump timing, was this enough to solve such emission?
    klangan ko na bng patingnan o pacalibrate yun pump ko? san nga po pala location ng shop nyo?
    hoping for your enlightening response....
    thanks very much
    Sep 2006
    Quote Originally Posted by shanejc View Post
    thanks very much
    Only two things you have to be sure of:
    1) Did you use an original air filter? Some replacement filters restrict air to the engine. Insufficient air will result in black smoke.
    2) Make sure that your injection pump to engine timing is on spec.
    If you are sure about these things, it his highly possible that calibration of your fuel injection pump and injectors may cure your problem.
    Bye,
    Dieseldude
    Apr 2011
    sir dieseldude,
    mine is a toyota tam fx a 2ct would like to ask bakit parang matakaw sa crudo ang ride ko ano po ang puwedeng icheck tnx po and more power god bless:-)
    Sep 2006
    Quote Originally Posted by greg2 View Post
    sir dieseldude,
    Perform these checks in this order:
    1) Check/replace air filter.
    2) Service EGR if installed.
    3) Tune up engine.
    4) Check injection pump timing.
    5) Check injection pump and injector calibration.
    Apr 2011
    Quote Originally Posted by Dieseldude View Post
    3) Tune up engine.
    salamat po
    You don't have to bleed the high pressure lines to the injectors if you are able to successfully start the engine after a fuel filter change.
    Apr 2010
    Nag leak ang injection pump (TD27, A/T) so binaklas, palit seals and calibration
    Nung binalik na sa akin, sobrang erratic ang shifting, hirap magdrive pauwi. Pero pag nilalagay sa Hold/Snow mode, medyo nagiging ok ang shifting
    May mga nabasa ako na may relation ang isang sensor sa injection pump na nagcocontrol ng shifting, so sinabi ko yung sa mekaniko ko. Pwede yun nga daw and kinuha nya kanina at ibabalik sa calibration shop. Kasi suggestion nya una eh mag change ATF, kakapalit ko lang last change oil (5k kms) and nung iniwan ko yung sasakyan, smooth ang pag shift
    Any ideas Dieseldude? Thanks
    Last edited by ParticleX; September 2nd, 2015 at 11:21 AM. Reason: Removed double post
Diesel Fuel Injection System Help Desk
