Results 61 to 70 of 2348
- Sep 2006
- 1,335
March 2nd, 2007 03:47 AM #61Yes, you are correct. You don't have to touch the injection pump if it is working properly. At 100k kms, you have to replace the timing belts though, as this will cause major engine damage if they fail.
You don't have to bleed the high pressure lines to the injectors if you are able to successfully start the engine after a fuel filter change.
- Sep 2006
- 1,335
March 2nd, 2007 03:52 AM #62Yes, you are correct. You don't have to touch the injection pump if it is working properly. At 100k kms, you have to replace the timing belts though, as this will cause major damage failure if they fail.
- Oct 2006
- 60
March 5th, 2007 03:36 PM #64
DieselDude,
Without dismantling the injection pump, pwede bang:
1. Check and adjust the Fuel Delivery Pessure ng injection pump? (For 4JA1, for example, .2 kg/cm2)
2. Adjust the injection timing of the pump to default setting?
Thanks.
- Apr 2007
- 62
April 7th, 2007 02:21 PM #65ano may ok. pa calibrate o carbon clean? kasi napansin ko.. mas mabilis tumaas rpm ko kaysa sa speedometer. pagumabot na ako ng 100 km/hr... rpm ko is nasa 3.5 dati... nasa 120km/hr 3.5 lang rpm. tama kaya ito? caibration ba needed for this? thanks.
- Jan 2006
- 113
April 7th, 2007 10:54 PM #66in new turbo diesels right now, is there any special maintenance you need to do for the turbo and intercooler?
- Sep 2006
- 1,335
April 8th, 2007 02:10 AM #67
- Apr 2007
- 62
April 8th, 2007 02:10 AM #68
- Sep 2006
- 1,335
April 8th, 2007 02:17 AM #69
- Mar 2003
- 149
April 9th, 2007 03:57 PM #70sir dieseldude,
I have this problem since i acquired my 2002 strada. Sort of a factory defect. The problem is whenever I am traversing a slope ( 10 degrees in my inclinometer), I am losing power especially from a halt. Parang mamatayan ako ng engine. What i do is apply my handbrake and rev my engine up to 2k then let go my handbrake to accelerate. Sabi ng mekaniko ko, kulang daw sa galit ang makina pag nire-rev. Medyo ipina-advance ko ang timing at medyo nakatulong kaso maingay ang makina at malakas sa diesel. what is supposed to be the problem? Thanks in advance.
Tesla Philippines
