Results 21 to 30 of 2348
October 4th, 2006 03:04 AM #21
tama nga, mas mabuti kung malapit lang sa makina at lagyan lang ng cooling fan para iwas butas, bato o tubig...
okey lang po ba ang pressure kung kahit anong intercooler ang gamitin ko like from Sportage o Mitsu 4d56 sa Toyo 3C-T namin? some thread I found here says that it may lose pressure if you add an intercooler, but Imo I don't find it negative since intercoolers have small passage.
o baka puwede rin yung intercooler ng evo?
someone posted in other thread that 4d56T intercooler surplus costs 3k-4k. Ouch... for spending just to have fun... sana may 2k, kung wala, baka nextyear ko nalang ituloy....Last edited by rion; October 4th, 2006 at 11:15 AM.
- Sep 2006
- 1,335
October 8th, 2006 10:47 PM #22
- Sep 2006
- 1,335
October 9th, 2006 10:03 PM #25
October 9th, 2006 10:56 PM #26
- Sep 2006
- 1,335
October 10th, 2006 01:20 AM #27
- Dec 2005
- 46
October 17th, 2006 07:46 PM #28Dieseldude,
What happens with a diesel engine with a too lean fuel mixture?
What happens with it if its too rich?
Whats the difference with an advanced injection pump timing and a retarded one?
Any info on these is highly appreciated. Thanks.
October 18th, 2006 12:47 AM #29Does the 3C-TDI originally have an intercooler? If this is an add-on you are planning, power gains will not be substantial.
Intercoolers are ideally located nearest the turbo's air discharge port and the engine intake manifold to save on hose, plumbing, and clamping costs, as well as to minimize on parasitic losses due to the added weight.
though there is another better location, putting it in the middle near the exhaust catalyst, will cost me just half a meter hose each... if I can find a smaller intercooler because the 4d56 intercooler is a bit big....
follow up question lang po, can I boost pressure in the turbo just by adjusting packing between the compressor housing and the wastegate mounting bracket with washers?
and should I increase the fuel pump timing after installing the intercooler?
determined po ako mag experiment but I'm still wating for my brother to go with me to buy the intercooler. madali kasi ako ma-oto eh...
additional question din sa engine knock... how about you hear knocks on idle, but on High revs nawa-wala naman...? is it an engine knock or something else?Last edited by rion; October 18th, 2006 at 01:00 AM. Reason: additional Q
- Sep 2006
- 1,335
October 20th, 2006 09:16 AM #30Try to do it one thing at a time. First, measure your engine's performance at it's present condition. Then add the intercooler and check performance again. Then, do the wastegate adjustment if you really want, and measure again. ........ then injection timing. This way, you can really gauge if improvement was gained in each modification phase.
