Results 1,861 to 1,870 of 2348
- Jul 2008
- 935
October 22nd, 2012 01:30 PM #1861
- Apr 2009
- 429
October 24th, 2012 03:50 PM #1862Good day guys. Does anyone know the Cetane rating of our diesel in the Philippines offered by our different gas stations?
Tnx
- Jan 2012
- 31
November 1st, 2012 09:14 PM #1863Mr. Dieseldude ,
i am working with a 2006 MITSUBISHI TRUCK 4M50 and i am getting a code of P0251 / CAM/ROTOR /FUEL METERING /INJECTOR .
i just want to know if you have encountered one of these already and what is the most possible cause of the trouble.
with tthis code , the truck has no power and eventually dies and hard to start .
if it falls into the injection pump or injectors , are you able to work on it ?
thanks
- Sep 2006
- 1,335
November 1st, 2012 09:59 PM #1864
- Jan 2012
- 31
November 2nd, 2012 06:54 AM #1865
- Sep 2006
- 1,335
November 3rd, 2012 01:18 PM #18662006 truck would most probably have a Bosch or Denso CR system on it. I was asking about your scan tool because it displayed 4 areas to check for a single DTC.
We have never worked on a 2006 US version Mits truck. But I believe this problem is within our service capability.
- Jan 2012
- 31
November 3rd, 2012 04:25 PM #1867Mr Dieseldude, i was searching for parts locally but it came out negative , my only option is to take the injectors and pump out for you to test them.
i have yet to come down to qc for follow up diagnostics but once confirmed that the problem is internal to IP or injectors , im going to ask the owner for this procedure.
i just wonder if you can give me a rough estimate for testing and rebuilding /repairing .
thanks for helping !
- Sep 2006
- 1,335
November 3rd, 2012 05:22 PM #1868
- Jan 2012
- 31
November 3rd, 2012 09:01 PM #1869
- Apr 2011
- 7
November 8th, 2012 10:54 PM #1870Sir Dieseldude, saan po banda yong Rod adjustment ng pajero 4d56 TDIC M/T para try ko po DIY na e-adjust? (Regarding sa Rough/smooth idling)
