Results 1 to 3 of 3
March 31st, 2009 12:25 AM #1
hi mga ka tsikot may prob ako sa suzuki ko 660cc carb type 3 cyl. pag nakaidle w/ a.c of ok pero [pag in on ko na dun namamatay mataas naman ang menor and isa pa pag finloor ko yung pedal parang bitin siya sa 2nd gear is 20kph parang hirap na hirap ayaw magbigay ng tulin tsaka iba tunog ng makina and isa pa pagtumatakbo sample ko is yung straight line
ganto siya ------____-----____----____---- meaning yung mataas parang takbo na normal pero may time na bumababa yung tapak ko naka ayos naman di ko itinataas...hope matulungan niyo ko kasi sabi ng mekaniko ko is change engine na daw pero napaka aga para magchange engine some say's na baka daw aircleaner fuel pump or yung carburador is madumi
March 31st, 2009 03:44 AM #2
I would get a complete tune up. You are suffering from what 90% of drivers are. Neglecting their cars. A tune up should help if you get the complete tune up * carb adjustments, cleaning, regular things it should be okey.
It's possible also that the A/C clutch and or pulley are locked up and either not turning or turning with too much resistance. Like you said, only when turning the a/c.
Do the tune up first then check as follow.
- Nov 2006
- 299
April 4th, 2009 07:58 AM #3baka hindi naman para sa kotse mo ang nilagay na ac compressor.ipacheck mo muna ang ac system mo bago ang makina.
Tesla Philippines
