Results 11 to 20 of 21
- May 2006
- 1,668
June 1st, 2019 12:02 PM #11Just drive normally and use all the features of ur car the first day you have it.
June 1st, 2019 12:40 PM #12
When I broke-in my 2019 Camry SE, I stuck to roads with 40 mph to 50 mph stop and go traffic. I kept RPM no higher than 4000. Later in the break-in period, I started using the paddleshifters and experimented with shifting at different RPM ranges, while remembering to keep RPM at 4000 or less.
Once the odometer went past 630 miles, the break-in period was over. Only then did I take the car to the freeway, accelerating to freeway speeds (65 mph to 85 mph) and taking it beyond 4000 RPM, usually 5000 and less than 6000 RPM for spirited acceleration (red line is 7000 RPM).
Oh. The manual stated the first 630 miles is the break-in period. It varies, depending on the car.Last edited by Jun aka Pekto; June 1st, 2019 at 12:43 PM.
- Feb 2014
- 2,658
June 1st, 2019 12:57 PM #13
June 1st, 2019 01:26 PM #14
do not race the engine...okay
do not drive constantly at full throttle...okay
avoid unnecessary hard stops...pwede
avoid full throttle starts...pwede
do not maintain one constant speed...ano daw rason? idiot kwestion lang[emoji848][emoji2960]
- Feb 2014
- 2,658
June 1st, 2019 02:07 PM #15
well be doubtful if it says sacrifice a goat or something. but that babad at constant speed is on every user's manual i've read but i'm not an engine nerd so i can't really say for sure. but i think it has to do w/ resonance. at particular engine RPM AND load certain spots on the parts are polishing against each other. if you vary the RPM or load other spots get polished
- Oct 2012
- 4,851
June 1st, 2019 02:49 PM #16Doable... 1k kms lang naman pala... [emoji106] thanks for sharing travi bai... sa instructions na yan parang sinasabi nila na gagamitin mo yung sasakyan na hindi masyadong agressive and not really conservative... hehehe for 1k kms... after that, you can go back to your driving style...
June 1st, 2019 03:01 PM #17
- Feb 2014
- 2,658
June 1st, 2019 04:47 PM #18
- Aug 2017
- 321
June 2nd, 2019 12:40 PM #19
- Feb 2014
- 2,658
June 2nd, 2019 07:28 PM #20
