Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    May 2007
    question lang po...
    what is the correct way of measuring oil in the dipstick? first thing in the morning when the engine is still cold? or do you need to warm it up first and wait for the engine to reach its normal operating temperature... turn off the engine and wait for 3-5 minutes then get the reading??? as stated by my SA in Tyt Otis. TIA
    i measure oil bago ko paandarin ang makina, yun ang natutunan ko sa tatay ko kasi sa ganyang state ng auto ang langis eh hindi nagcicirculate, IMO lang po
    Aug 2006
    Measure the oil after it rested for some 5-10 minutes, when most all the oil drips back to the oil pan. Also take note that the car is on level ground.
    May 2007
    yan din po ang alam ko eh kaya medyo duda ako sa sinabi ng SA sa Otis... nagpa PMS kasi ako sa kanila...nung nicheck ko ung langis eh medyo sobra ng konti sa F indicator kaya tumawag ako sa kanila para i clarrify... masama po ba pag sobra langis? balak ko kasi ibalik para idrain ng konti.
    Mas mabuti po ang kulang ng konti kesa sa sobra...masisira ang oil seals pag sobra..
    oo, mas maganda ang kulang kesa sa sobra. kahit mga 1 guhit lang ang kulang para sa full, ok na yun.
    yun ba ang sinabi ng toyota sa yo? kaduda duda nga talaga kasi hindi naman tama na pag-on mo ng makina, kuha ka ng langis kasi ang langis eh aangat na yan at magcicirculate
    May 2007
    Quote Originally Posted by Mile2 View Post
    so my SA is correct pala in saying that... kinda got used kasi to the practice of checking the oil first thing in the morning when the engine has rested overnight. thanks Mile2
    May 2007
    Quote Originally Posted by oliver1013 View Post
    pabawasan ko na lang ng konti bukas. maraming salamat po
    Aug 2006
    mas hirap ang makina pag sobra sa langis.
    Aug 2005
    Best way to measure it is on even ground, and prior to re-starting the engine. Sa dipstick merong 2 dots. Oil level should be in the lower dot indicator or in between those 2 dots. Avoid overfilling your engine. Isipin mo na lang na napakalakas ng pressure sa loob ng engine mo pag tumatakbo kahit na nasa normal oil level ito, what more kung sobra?
Correct Way of Measuring Oil
