Results 1 to 10 of 14
- Aug 2016
- 252
January 16th, 2017 11:12 PM #1Hey, Im having problems with a big body corolla gli with high idle (about 1500-2000 RPM engine at operating temps)
Checked the iacv, tps, map, smoke (or vape) tested for vacuum leaks. all in good order... anyone had these problems before? share naman your experiences and what you did to solve.
Thanks in advance!
- Aug 2016
- 252
- May 2011
- 481
- Aug 2013
- 475
January 17th, 2017 01:18 PM #4try mo ito to run engine diagnostics sa 4afe mo.
http://bgbonline.celicatech.com/93ce...gnosis4afe.pdf
- Aug 2016
- 252
- Aug 2016
- 252
- May 2011
- 481
January 17th, 2017 03:02 PM #7
bear in mind, the coolant temperature gauge sending unit is different from the coolant temperature sensor. a miscalibrated or out of bounds CTS will not show on OBDI code request from the on board diagnostic terminal adjacent to the airflow meter. you will have to check the resistance of the sensor in relation to its temperature.
- Aug 2016
- 252
January 17th, 2017 03:15 PM #8
- May 2011
- 481
- Aug 2016
- 252
January 17th, 2017 04:01 PM #10
