Results 1 to 10 of 10
    Apr 2009
    What value does it really give? What do I get out of it?
    What's so special if I have a high specific output for my engine?
    Why did Honda brag about the 100 hp/li B16A engine when it first came out?
    High horsepower rating = engine is more powerful on top-end, has faster top-end speed
    High torque rating = engine is more responsive
    High specific output rating = ??????
    Take this case between a 1.3 and 1.6 engine where the 1.3 gets more specific output:
    Mazda B3 (Gen 2.5)
    73 hp / 1.3 liters = 56.15 horsepower per liter
    Mazda B6 (Astina)
    88 hp / 1.6 liters = 55 horsepower per liter
    Does that mean I can almost "feel the same power" when I downgrade to the 1300 engine?
    Dec 2007
    It's an engineering feat more than anything else.
    The usual ways of making more power from an engine are
    1) increasing displacement
    2) adding boost
    3) increasing compression
    Imagine your engine is an air pump. The more air that it takes and expels, the more powerful it is. That's the whole point of an engine really.
    Engine makers have moved the engineering game by making more power out of small engines (hence higher specific output). For Honda it was via sky-high RPM and the valve lift/timing trickery called VTEC. For other carmakers, it was via better-controlled fuelling (carburetors vs. mechanical injection vs. electronic injection).
    Specific output is power developed per unit of engine displacement. It's got more to do with HP than torque, which your post explains well.
    Dec 2007
    To add to my post above.
    High specific output is also beneficial from a taxation point of view. Many countries tax vehicles by engine displacement: the larger your engine the more tax you pay. If your small engine can make just as much power as a big one, you can skip out on the tax.
    Larger engines are also usually heavier like-per-like vs. small ones, unless engine builders resort to exotic materials and/or construction techniques. More weight means more fuel burned.
    It can be argued that in many situations drivers don't really need all that much power...but when you do need it it's nice to know it's there. Supposedly that's the allure of an engine with two characteristics - quiet, docile, idles nice and saves gas at low RPM but punchy and powerful at high RPM.
    Apr 2009
    Thanks for the reply.
    Now here's my dilemma, assuming both engines bolt on the same vehicle, say a Sentra GX:
    Nissan SR20DE (JDM) = 140 hp/2.0 li = 70 hp/li
    Nissan QG13DE (PHDM)* = 95 hp/1.3 li = 73 hp/li
    [SIZE=1]*NMPI claims 95 hp as per brochure for the Sentra GX[/SIZE]
    It's a given that the SR20DE has much more hp and torque rating.
    But based on computation, the QG13DE gives more specific output.
    Is it safe to say that the QG engine makes power more efficiently because it can give 3 more horses per liter?
    Although I know that in the end, the SR will yield much more because it's got 700 cc more, hence more volume to accomodate fuel to burn.
    Aug 2004
    More efficient in terms of peak power per liter.
    But it doesn't tell you how much power the engine has "under the curve".
    The Engine Masters series in the US uses both peak and average horsepower to grade their engines.
    To get the average (for performance purposes), you'll need a dyno chart and you'll need to know where the 1st-2nd gear shift (typically the longest) lands you. Usually at 4k rpm in 2nd gear for a gasoline engine and 2k rpm in 2nd gear in a diesel engine.
    Measure out the average to redline. That's your useable power band.
    I did one before to compare the Lynx RS to the Focus TDCi. The Lynx averaged around 118 whp (from 4000 - 6500, measurements every 500 rpm). The Focus averaged around 125 whp (from 2000-4500 rpm). So, despite my Lynx making 148 whp at peak (around 178 bhp) and the Focus making only 135 wp at peak (around 150 bhp), the Focus diesel engine still made more power in real life. Which is why they're just as fast as each other in terms of pure acceleration, despite the Focus being heavier.
    Still, comparing average hp to liters will still give you a hp/liter metric... but what's more useful to performance builders and tuners is the hp/kg metric. How much power does an engine make compared to how much it weighs? Considering the TDCi motor weighs about 100 kilograms more than a gasoline 2.0 motor (typically weigh around 150 kgs)... the power per weight density really isn't very good... but it makes up for it by being very, very, very fuel efficient.
    i hope we can continue with this thread. i too have questions, maybe similar to thread starter but too techie for my layman mind to comprehend.
    am comparing two engines: Urvan and Starex TCI and they have different measures thus can't easily compare like apple-to-apple .
    Output 100ps/3800rpm 84hp/4300rpm
    Torque 23kg/2000rpm 178nm/2200rpm
    The second column are values for TCI and the last column values are for Urvan.
    What do these mean in real world? Maybe it's safe to assume that Starex TCI can run faster (top end speed), has more hauling power and even accelarate faster. If all those are true, by how much (%)? salamat.
SPECIFIC OUTPUT in layman's term
