Results 1 to 5 of 5
    Feb 2013
    Hello,bakit kaya pag cold start ko ay grabe usok at ang baba idle sasakyan ko.pag uminit na after 5 minits idling ay biglang tataas idle at ok na usok.normal na lahat.pino na andar.toyota liteace 2c-turbo car ko.salamat sa mag bigay inputs tungkol dito.
    Quote Originally Posted by glxexurb View Post
    several things might be at play here, try to do/check the usual/obvious first, change if you cant remember the last time you changed the following: air cleaner, fuel filter, engine oil( you can shift to synthetics para hindi hirap sa cold start). if not then pasok na sa shop look for those that specialize your vehicle, - they have special powers and know what might be wrong with your veh simply by looking and listening hehe.
    Feb 2009
    have a compression check, turbocharger checked for oil seal wear or damage. check your oil viscosity and quality.
    Feb 2013
    paano ba ang compression test at paano mo malaman kung may damage o sira ang turbocharger sasakyan?salamat
    Feb 2009
    compression test is done using an adaptor to the glow plug hole. the turbo charger can be checked at the compressor wheel if there is oil trace or accumulation. have a competent shop do these procedures
Cold start mausok at ang baba idle
