Results 1 to 10 of 19
- Jul 2016
- 44
September 21st, 2016 12:41 AM #1chevy optra matic unit ko.
binabaybay ko kahabaan ng nlex ng biglang namatay engine ko speed at 80-100. (kung kelan nsa nlex namatay , nun nsa traffic hindi)
then hard start n sya. pinag pahinga k lang ng ilang minuto ok na uli.
ANO PO KAYA ISSUE NG AUTO KO? SALAMAT SA MGA SASAGOT ! ! !
September 21st, 2016 08:24 AM #2
Overheating engine? Check temp and radiator water level.
Sent from my SM-N930F using Tapatalk
- Nov 2008
- 641
September 21st, 2016 08:58 AM #3
September 21st, 2016 09:18 AM #4
Several possibilities from a fuel pump, to crank sensor, to a clogged fuel filter, to ignition (is the Optra direct ignition or utilizes an ignition coil?). You will have to observe and check these items one by one and have a scan done as well perhaps.
- Jul 2016
- 44
September 21st, 2016 09:15 PM #5
- Jul 2016
- 44
September 21st, 2016 09:23 PM #6ngayun...
check engine light on naman sya. nag pa karga lang ako fuel eh pinatay engine ko. pag start ko d agad nag start misfire lang tapos nag start n sya sa 2nd try ko.l tpos lumabas na check engine light... help!?
- Sep 2009
- 387
September 21st, 2016 09:45 PM #7Well, that leaves you no choice but to bring it over for a repair. Better if you could have it towed.
September 21st, 2016 10:00 PM #8
Since may check engine light na, theoretically mas madali na ma-pinpoint kung ano ang problema talaga ng car kapag mapabasa mo sa shop na may obd ii scanner
to be or not to be, that always confuses me!Last edited by baludoy; September 21st, 2016 at 10:02 PM.
September 21st, 2016 10:46 PM #9
BANNED BANNED BANNED
- Sep 2014
- 8,492
September 21st, 2016 10:48 PM #10Hi-tension wire yan, pag mabilis ka nag hi-tension si kaya nasira na, pero pag traffic ok lang
Palit ka hi-tension wire
_________________________________
If you are wrong, turn right.
If you are right, turn left.
