Results 1 to 10 of 11
- Jan 2005
- 445
December 7th, 2009 12:29 AM #1Guys,
Patulong naman, nabalian ng eh ang owner ko na toyota rwd. May idea ba kayo kung paano ko malalaman kung aling side ang naputol?
Thanks,
Reym.
December 7th, 2009 12:44 PM #2
wild guess lang to ha. try mo naka primera ng patay ang makina tapos i-jack mo ang likod tapos paikutin mo yung gulong. kapag umikot ayun siguro ang bali. hula lang to hehehe
- May 2006
- 913
December 7th, 2009 01:35 PM #3i would think you can just pull out the side with the broken axle. unless you have full floating axles..
- Jan 2005
- 445
December 7th, 2009 06:43 PM #6Thanks a lot guys! Kainis kasi owner pinuputulan pa ng ehe para kumitid, tapos duduktong din naman. hehehe.
BANNED BANNED BANNED
- Dec 2009
- 322
December 8th, 2009 09:51 AM #8
Bili ka na lang ng surplus na differential mas mura pa kaysa magpa press kang axle bearing. P1,500 lang dati ang bili ko ng buong surplus differential.
Yung luma pakilo mo, bawi ka pa kaunti sa pinambili mo ng differential.
Dati nagpapalit pa ako ng axle bearing sa owner ko, pero mas mahal pa lumalabas kaysa palitan ko ng buo na surplus differential. Minsan makakakuha ka pa ng maganda pa ang brake drum.
- Jan 2005
- 445
December 9th, 2009 05:58 PM #9Guys,
Thanks a lot, inangat ko 1 gulong umikot ang propeller, ingangat ko ung isa, umukot din. so its not the axle, binaba namin transmission, basag ang clutch lining at sunog. Pinalitan ng release bearing,presure plate at lining.
Pag patay makina nakakambyo tapos pag release umuusad, ibig sabihin buo ang axle, ngayon ayaw pumasok ng kambo kahit saan ilagay, kapag tinodo adjustment pa taas may tumutunog ng toktkotok. Ano kaya problema???
December 9th, 2009 11:05 PM #10
kapag sobra ang transmission oil tumitigas din ang kambyo. check mo muna yun.
Tesla Philippines
