Results 1 to 5 of 5
- Feb 2013
- 42
February 22nd, 2013 08:33 PM #1Hello,bakit kaya pag cold start ko ay grabe usok at ang baba idle sasakyan ko.pag uminit na after 5 minits idling ay biglang tataas idle at ok na usok.normal na lahat.pino na andar.toyota liteace 2c-turbo car ko.salamat sa mag bigay inputs tungkol dito.
February 23rd, 2013 10:53 AM #2
several things might be at play here, try to do/check the usual/obvious first, change if you cant remember the last time you changed the following: air cleaner, fuel filter, engine oil( you can shift to synthetics para hindi hirap sa cold start). if not then pasok na sa shop look for those that specialize your vehicle, - they have special powers and know what might be wrong with your veh simply by looking and listening hehe.
February 23rd, 2013 12:15 PM #3
- Feb 2013
- 42
February 23rd, 2013 06:01 PM #4paano ba ang compression test at paano mo malaman kung may damage o sira ang turbocharger sasakyan?salamat
February 23rd, 2013 06:19 PM #5
Tesla Philippines
