Results 1 to 8 of 8
February 17th, 2010 10:44 AM #1
Magandang araw po sa lahat.
The car is Honda City 2004. Just recently encountered "MIL" or "CEL" on my car. Usually nung na-encounter ko to before ay on and off lang ang ginagawa ko then nawawala na sya agad. Pero last week ay di na sya nawawala.
Since halos weekends ko lang ginagamit sya recently, yesterday ko lang pina-diagnose sa isang branch ng servitek.
Below is the result of the scan test.
X431 DIAG Report Launch
SMARTBOX:980248739900
DATE: 2/16/2010 10:33:02 AM
Total Codes :001
CODE001:
14-3 IACV CIRCUIT FAILURE
Ang ginawa lang nila ay ini-spray ng contact cleaner yung ibang terminals. After awhile nawala naman. Umuwi na ko since parang ok naman then parked the car at pumasok na ko sa office. Nag half day lang kasi ako para dun.
Then last night ini-start ko ulit sya, then after ilang seconds umilaw ulit siya. So I searched on the net and try to check kung ano pwede gawin. Halos di tuloy ako nakatulog.
This morning, I started it again and nandun ulit yung CEL. So ginawa ko, I drove it around 2kms siguro. Then saka lang sya nawala. Nung naka-ilaw sya medyo di talaga maganda yung takbo nya but nung nawala na yung ilaw ok na ulit sya.
What do you think guys? May iba pa kayang sira ito? Makuha kaya sa cleaning lang ng IACV to? I want to make sure na sira talaga siya bago sana palitan. Magkano kaya replacement parts nito?
Your opinions are highly appreciated. Thanks in advance...
February 17th, 2010 06:50 PM #2
looks like an intermittent problem. as the mil code said; it's a circuit problem not necessarily a defective iac, check the wires, (better if yo have a wiring diagram). try the wiggletest, check for corrosions and tightness of the connectors and terminals. while it's not acting up you can check the iac by pulling out a vacum, if the idling rises then the iac is still good.
BANNED BANNED BANNED
- Jul 2003
- 2,267
- Jun 2009
- 325
February 18th, 2010 12:28 PM #5Suggest na ibalik mo sa gumawa nyan before. Dapat ma- correct ang trouble code. Baka in-erase lang ang trouble code, malamang babalik uli yan. Pa check mo mga wire harness, connectors going to the IACV. The mechanic should know the location of the IACV. I think naka indicate location nyan sa scan tool.
- Feb 2008
- 73
February 20th, 2010 02:55 PM #6there is an iacv magnet inside which needs to be replaced. had exactly the same problem. 1,800 for the magnet and 400 for labor. cleaning included. di ko nga alam kung nabundok me sa presyo...
February 22nd, 2010 02:07 PM #7
March 19th, 2010 12:02 PM #8
update lang just in case meron same problem.
last saturday while driving, the CEL went on again. so the erratic idling and jerking comes back again. i brought the car to hondakal and inquired for the part which is Rotary Air Valve Control (RACV). Eto pala yung tawag ng honda sa IACV.
it costs me +9k including air cleaner element and labor for the installation. hinabol ko kasi dahil magtataas na naman daw ng parts ang honda. buti na lang meron pan natitira dun sa last batch nila na tag 7.3K. yung next batch kasi nila 11K na daw IACV...
the car is working fine now...
Tesla Philippines
