Results 1 to 9 of 9
    Mar 2012
    Hi guys, anyone here experienced this problem in shaking?
    Napansin ko lang kasi naginginig sya everytime na nakabukas ang AC at naka-drive/reverse and kambyo and I step on brake. Pag umaandar naman swabe lang.
    While AC is off, normal 1k and idling pag bukas ng AC bumababa na sya up to 700 and shakes, medyo nakaka-irita. Pag Neutral naman walang shakes. So ang ginagawa ko, pag stop, nag Neutral na lng ako kasi nga it shakes habang nakaapak ako sa preno. Sometimes di na lang ako nag aircon.
    Any tips mga sir, baka kaya sa DIY. If not ano kaya ang dapat kong ipaayos?
    Car is Mitsubishi Lancer 1997 GLXI (Pizza), Matic
    Feb 2009
    Quote Originally Posted by macmat View Post
    for fuel economy, your car has a very small engine. when you in gear with A/T, shift to neutral or turn A/C off to avoid shaking. if you are able to adjust the A/C idle up manually, you can raise it up to the idle speed while the A/C is on.
    Mar 2004
    Have your engine mounts checked.
    Jun 2007
    Im not quite sure with lancer pizza but for its bigger bother the galant this is a common problem of the galant 7g and 8g, culprit is a broken servo. The servo acts as a old school idle up device.
    baka masyado mababa idling... have it adjusted... kung hindi na ma-adjust, may problema na yung servo siguro... a common problem with mitsubishi cars... yung lancer itlog namin nagpalit kami ng ganyan dati. plug and play part pero mahal, nasa 10k ata nun way back 1999.
    Dec 2010
    when braking lang???? try mo pa check yung check valve yung hose sa hydrovac ng brake. or may air leak ang hydrovac nyan.
    Oct 2009
    kung when braking. check mo din rotor mo baka warped na.
    Jul 2012
    same problem with my car. kapag nakaapak sa break, lakas ng shake kaya lagi na lang akong naka neutral pag naka stop. Sabi daw engine support nmn ang prob. Tpos mahirap dw gwin kasi modified na yung current engine support ko. Btw, mitsubishi galant 95 matik. Engine changed from 6cyl to 4cyl..
    Malamang brake judder yan dahil sa warped brake rotors.
Car shakes when braking
