Results 11 to 20 of 21
May 5th, 2015 08:23 PM #11
Yung click sound relay yun. Pumapalo yung relay pero di nagreredondo due to 1 or more of the following:
1. Loose or dirty battery terminals. Retight and clean.
2. Low battery voltage. Maybe bad charging system, or battery already not charging. Napalitan na ba ng battery?
3. Starter solenoid contacts damaged. This is the most probable cause in your case since you said the lights do not dim when you try to start the car (i am assuming tama description mo ha). Pag on ang headlights at di nag-dim pag start mo then that is a good sign the starter solenoids are not making any contacts at all.
- Jun 2011
- 91
May 6th, 2015 08:26 AM #12
May 6th, 2015 10:38 AM #13
May 6th, 2015 10:51 AM #14
- Sep 2014
- 41
- Nov 2019
- 1
November 13th, 2019 01:38 PM #17Looking for advice from car expert friends here. Gist is I have a car electrical technician who owns his own shop say one thing and my Casa (car dealer) say another thing needs to be done. My predicament is who do I listen to?
If you are still reading along, details are: Honda City 2014. Push button start. electrical technician said there is a malfunctioning grounded terminal in my car alarm causing my battery to drain. No problem with my starter. He said bring it in to the Dealer to have Alarm electrical checked. Dealer said, your Starter needs to be replaced because your solenoid (or some technical sounding thing) is already corroded.
I am torn who to listen to. Any suggestions?
- May 2014
- 1,318
November 13th, 2019 02:19 PM #18
Tsikot Member Rank 3
- Nov 2002
- 1,770
November 13th, 2019 02:25 PM #19
- Apr 2014
- 473
Tesla Philippines
