Results 11 to 20 of 24
    Dec 2012
    what year is your car? how many miles? what was the last thing done to it? did the symptoms start after you refueled? is the exhaust system clogged? do you have throttle by wire? what is the engine vacuum measured at the intake manifold at idle speed?
    year 2000
    last thing done, replaced distributor o-ring
    no, not after refuel.
    don't know if the exhaust is clogged.
    not sure what is throttle body by wire.
    I don't know the engine vacuum
    Dec 2012
    Yup, I'd agree on this one.
    TS: Have your car scanned for trouble codes. Or try a hard reset, disconnect your negative cable from the battery for a few minutes, then reconnect. Then tell us what happened.
    I'll try the hard reset. if it doesn't solve it, i'll have it scanned. Thank you sir.
    Feb 2009
    Quote Originally Posted by madduck View Post
    year 2000
    have the ignition timing checked and maybe adjusted.
    chances are the ignition timing is late and should display lower than 18 inches of mercury vacuum at the intake manifold at idle speed
    Dec 2012
    how would i know if the ignition is adjusted correctly? Thank you.
    Feb 2009
    you can have this done in different ways:
    1-using a scan tool with the engine running and go to engine parameters
    2-using a stroboscopic timing light aimed at the timing marks after all the prerequisites are satisfied
    3-if the two above are unavailable, you can use an inexpensive engine vacuum gauge connected to a non ported vacuum source on the intake manifold
    4-if the shop you have been going to is incompetent or has incompetent "mechanics", go to another shop with equipped, trained and experienced technicians
    May 2011
    how can you rev the engine when you're running?
    advancer mechanism is out..?
    Feb 2009
    ga16e, ga16de, ga16dne all have electronic spark advance system. no centrifugal advancer, no vacuum advancer
    Dec 2012
    Update
    1. MAF Sensor cleaning - wasn't able to do this over the weekend, I can't find a MAF Sensor cleaner. I have a CRC Throttle Body cleaner, can I use it instead?
    2. Battery disconnect - I have disconnected the battery over the weekend.
    3. Ignition timing - the shop where I regularly goes to doesn't do this. I've read the stock position should be somewhere in the middle, I checked my distributor and it is in the most reversed (delayed) position. I turned the distributor forward to be approximately in middle position. I'll try to have my ignition timed properly next time.
    The car ran smoothly. The problems mentioned earlier seems to be gone.
    I'd still like to clean the MAF sensor and the IACV as well, if I can just figure out how to remove that IACV hehe.
    Thank you for everyone's help.
    Feb 2013
    You can use Mr. Mckenic Fast Dry Contact cleaner.
Can't rev when running
