Results 1 to 10 of 24
- Dec 2012
- 304
August 16th, 2013 08:11 AM #1The engine can rev properly in idle.
Can't rev past 1800 RPM kapag paakyat ang road. Hindi tuloy makahatak.
Can't rev at all kapag naka ON ang aircon.
RPM drops kapag bumabagal.
Pleas help. Car is Sentra, GA16DNE.
BANNED BANNED BANNED
- Feb 2013
- 487
- Dec 2012
- 304
August 16th, 2013 09:26 AM #4
Perhaps it could be MAF (Mass Air Flow) sensor issue. Try having your throttle body opened and cleaned along with the MAF sensor. A diagnostic engine scan should help.
- Dec 2012
- 304
August 16th, 2013 11:26 AM #5I've cleaned the throttle body, last month, pero nilinis ko lang ng nakakabit pa. I'll clean MAF, thanks sir!
August 16th, 2013 11:39 AM #6
Sounds like it could be on limp mode. Is the CEL on? Have the engine computer checked for DTCs.
August 16th, 2013 11:52 AM #7
- Dec 2012
- 304
August 16th, 2013 11:55 AM #8it is when turning the key ON but it turns off after starting.
Where can I have the computer checked? Sa casa lang po ba available yan?
August 16th, 2013 12:15 PM #9
August 16th, 2013 12:35 PM #10
if the car is OBD II compliant, disconnecting the battery does nor erase the codes. it will be in the memory as history code. the only way to reset this kind of situation is to repair the cause of the problem and reset using the clear code function of the scan tool not a code reader alone
Tesla Philippines
