Results 1 to 8 of 8
- Apr 2008
- 39
March 8th, 2010 10:45 AM #1mga bossing, question po... ung 2000 gas revo ko pag start mu ung makina, ok naman ung RPM nya, nasa 9 b un? pero pag on mu n ung aircon e bumababa hanggang 2 ung RPM nya, hanggang sa parang mamamatay na ung makina kung hindi ko aapakan ung gas. salamat po sa mga inputs!
March 8th, 2010 12:32 PM #2
check you idling speed.
check your battery, baka mahina na. aircon takes it electricity from the battery, not from the alternator. check mu din alternator, baka mahina karga.
pero if di naman namamatay ng tuluyan, baka low idle lang
- Oct 2009
- 72
March 17th, 2010 07:19 AM #3If the MIL (malfunction Indicator Lamp) or sometimes they call it CEL (check engine light) does not illuminate, your most likely problem would be a sticking Idle Motor Actuator (this controls you idle speed when you turn on you a/c, or stabilizes your idle speed whenever the computer detects from you a/c, p/s, headlamp.
- Oct 2009
- 72
March 17th, 2010 07:37 AM #4
Pardon me, but this is hard to let go. All electrical loads when the engine is running will come from the alternator, provided the alternator can supply the demand, when the demand exceeds the supply they battery will provide it.
His vehicle is is a 2000 Revo with EFI engine, the computer manages the engine idle.
March 17th, 2010 08:40 AM #5
ito ang pagkakaintindi ko sa revo and other efi cars.
initial during engine initial start (engine cold) approx. 1300rpm
gradually will stabilized to 650rpm
no load approx 650 rpm
load will increase by demand (brake, electrical)
by approx 150rpm
load will increase to approx. 850rpm
when a/c is selected to on
thru idle up.
check mo muna ang throttle mo baka madumi na,
baka bara na ang mga ports sa loob
then check ang mga vacuum hose for leak .
then check ang idle up baka di na gumagana replace mo na
- Jan 2010
- 107
March 20th, 2010 02:43 PM #6Sirs, ask ko lang po; yung grand vitara 2.7 v6, ok ang idle, ok response pag tapakan selenyador; pero pag nilagay sa reverse or drive (a/t po), bumababa idle hangang mamatay.. would appreciate your opinions po kung anu sa tingin nyo problema, at kung ano solution? Many thanks in advance po..
March 23rd, 2010 12:04 AM #7
Its the Idle Air Controller Valve/servo in most cases. Have it checked . .
- Jan 2010
- 107
Tesla Philippines
