Results 511 to 520 of 1184
- Jul 2009
- 2,618
March 4th, 2020 03:08 PM #511Mahal pala bili ko sa Wix noon sa lazada. 400pesos for Mitsu 4d56. pero I must say i was impressed with the finish and quality. Made in Portugal I think.
- May 2017
- 2,116
March 4th, 2020 06:01 PM #512
- Dec 2013
- 527
March 5th, 2020 02:20 PM #513Hindi ata ganun ka kumpleto numbers sa WIX site, pero pwede kayo maginquire sa WIX authorized distributor sa Philippines.
WIX Filters by Hesler - Home | Facebook
This is their contact numbers:
09178405901
8740-2412
- May 2019
- 33
March 6th, 2020 12:46 PM #514Saw wix filters sa autosupply malapit sa school ng anak ko. 190 lang vs 220 for vic..
- Nov 2014
- 454
March 31st, 2020 03:39 PM #515First time user ng WIX 7119 for our Ertiga Gen 1, sa Laz 350 kasama na delivery charge
So far okay naman takbo paired wirh Mobil Super 2000 5w30.
Anu ba symptoms pag bad / fake ang oil filter?
Sent from my LG-M700 using Tapatalk
March 31st, 2020 04:43 PM #516
- Dec 2013
- 527
April 23rd, 2020 12:59 AM #517It really depends on how bad of a quality the fake oil filters are, there are times na lalabas kagad symptoms like oil leaking from the bad quality oil filter from its rubber gasket, other symptoms are exploding oil filters which is worse since either the filter could not take extreme pressure, others might take years to know the extent of the damage when you're going to overhaul an engine na, since bad filters will not filter out the contaminants from your engine and those contaminants will the ones that will be damaging your engine parts like piston, piston ring, cylinder liner, con rod bearing & other parts that are being lubricated by the contaminated engine oil, always remember kahit anong ganda pa ng engine oil mo once paired with a bad filter the engine oil will not perform as it says it could perform since the engine oil will be mixing with dust, ashes & other contaminants. Also take note AIR and FUEL filters are as important as the oil filter dahil once contaminants passes through the air and fuel filter it will still contaminate the engine and the engine oil, running an engine with a good filter and good oil will not do you any good if you use a cheap China generic or private label/brand or K&N & other racing filters since in the end you'll end up getting the same contaminants in the engine and in the engine oil every time your engine sucks air/oxygen through the bad air filter and dirty fuel from the bad fuel filters.
Proof that K&N and other racing filters are bad at filtration and are just plain hype, please watch the link below from Youtube:
Which Car Air Filter is Best? Let's find out! Fram, K&N, Wix, Purolator, & AC Delco showdown - YouTube
- Dec 2013
- 527
June 25th, 2020 04:04 PM #519
- May 2017
- 35
June 29th, 2020 01:42 PM #520
